FILLED REAR TIRES ON 3616
   / FILLED REAR TIRES ON 3616 #31
Rim Guard suggests that any tire filled have a metal valve stem. Max series have rubber stems, so if any of you are considering a DIY on Rim Guard, replace the stems first. That requires breaking the bead which isn't so hard. But it is difficult to regain the bead seal if you do not have a blaster tank.
If you are going to go with Rim Guard, you should check installed price at your nearest dealer before you spend too much time getting adapters an pumps and stuff. Dealers stock it in huge tanks, so if you bought just the product you would need buckets or a tank or something to haul it....might as well have them put it in your tires and haul it that way. It is sort of like syrup, so a little harder to pump than most stuff. It has the appearance of a viscosity about equal to engine oil.
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2016 Ram 5500 4x4 Altec AT37G 37ft Bucket Truck (A50323)
2016 Ram 5500 4x4...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
T3 Motion Patroller Segway (A51694)
T3 Motion...
John Deere 1020 Tractor (RUNS) (A50774)
John Deere 1020...
