Tires filled tires.....gooooood
   / filled tires.....gooooood #31
Regarding using inner tubes with the RimGuard, my dealer on a L4740 purchased last month stated they always place a tube in the tire before loading. I thought it was unnecessary since RimGuard is a corrosion protectant, but maybe it was due to "rim-spin". Hadn't thought about that, and guess I could have inquired more as to their reasoning. But figure the more layers between moisture and unprotected metal is always a good thing.
Likely it's for "insurance", especially with R-4 tires.
When we loaded my Dad's R-4 tires a few weeks ago, at first we were not going to put tubes in... but as soon as we let the air out of the tires, the beads broke on their own. Sure would make a mess to have that happen when the tire was 1/2 full or more... as the mechanic were we got the RimGuard from attested to... said the same thing happened to him once... and from now on he will only load tires with tubes.
   / filled tires.....gooooood #32
You can try it with water to give you an idea about how they feel filled. Then if you like you can get rimguard in the fall for the year round protection and an xtra 70# or so.
Problem I have heard of with rimguard w/o tubes is lubrication of the bead and rim spinning in the tire.:eek:
larry
good idea - test your machine with water and if you like it, upgrade to something with anti-freezing.
tires spinning with rimgaurd!!!! :eek: now, now - don't be running around and scaring rimguard owners;) . knock on wood, hasn't happened to me yet.
Found it
http://www.tractorbynet.com/forums/owning-operating/80954-filled-tire-problem.html
   / filled tires.....gooooood #33
Hi,
I don't get here too often these days (should say years...:eek:).
When I got my BX2200 I had the front tires foam filled. I did not weigh them, but walked into the shop with one in each hand, and there was no way I was going to carry them out to my van except one at a time when I picked them up.
At that time I filled the rears with windshield washer fluid using a little drill-powered pump. After about 4 years I got my first rear puncture (ag tires) a couple weeks ago. I decided that I would not deal with anymore punctures with liquid filled tires, and drained the WW fluid and took the rear tires to the shop and had them foam filled.
They had a sample of foam at the tire shop, that they called zero pressure foam, as it was formed in a cup and set up under no pressure. It had the consistency of something like a dense jello or angle food cake. Pretty dense naturally. But still soft and springy.
When they fill the tires at this shop they check the pressure rating and pressurize the foam to about 10 percent less than the tire.s rated pressure.
The tires have flex and seem sort of similar to the way they felt when liquid filled. Maybe a bit stiffer, but they do flex when I push them with my foot.
I paid $111 each per tire, plus sales tax on top of that for the foam filling.
I checked the weight of the rear tires on a bathroom scale and they came in at 181 lbs each.
Hope I don't get a puncture in the rear tires on my B2910 which are liquid filled. My guess is the tires on that tractor would cost $300 to have foam filled, but that is only a guess...
All in all I am happy with the foam filled tires on the bx and should have done it in the beginning...but only feel that way since I got a puncture!
Just another data point for those interested...
   / filled tires.....gooooood #34
Ok, so what do you guys think about filled versus wheel weights?
Weights can be added or taken off... but I don't think they can get as heavy as the filled, right??
Any other comments?
   / filled tires.....gooooood #35
Any other comments?
According to my dealer, the weights I had put on my new BX2660 are a little heavier than filled tires. It may depend on the size of your tractor and intended use. We have used filled tires and weights on our farm tractors.
   / filled tires.....gooooood #36
i'm going to soon buy a 2920 and looking at putting weights on it from day one....
40006 (A55788)
40006 (A55788)
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
2004 FREIGHTLINER CL120 TANDEM AXLE DAY CAB (A57880)
2004 FREIGHTLINER...
