Finally used the Brush Cutter today
   / Finally used the Brush Cutter today #1
Highridge
Southeast, MA
Power-Trac 1430 and Craftsman DGT6000
Today I finally used my 60" brush cutter that I got when I purchased my used 1430. Let me tell you that this machine can clear brush fast! /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif There were a few clusters of saplings that I ran over a few times and then they were gone /forums/images/graemlins/shocked.gif! I kept remembering the video from MossRoad's website with him running over the big rosebush! I'll be getting somemore time with it Friday at my FIL's house.
Here are some pics of the brush cutter. I'll take some pics of the area that I'm clearing this afternoon.
This is a cool picture /forums/images/graemlins/cool.gif
Pic of the blade and spindle.
   / Finally used the Brush Cutter today #5
Cool. 60" beast. /forums/images/graemlins/grin.gif
   / Finally used the Brush Cutter today #6
Nice looking unit - /forums/images/graemlins/cool.gif
I'm not a PT owner, but a potential wannabe and was wondering about the limits/potential of this cutter. How large in dia. is it rated for? How high can grass be for cut to be clean? Do you have before and after pics of the area you were cutting? I saw MR's video clips too - impressive - but how long can these units sustain this type of use?
I currently use a NH TN75 w/rotary cutter on my property, but have some hills I can only cut by backing down, which is tough on my neck after mowing all day. Thus the reason I am looking at some supplemental help and considering something like the 425 or 1425 to use to mow hill areas and between trees.
The problem is, most of the area I mow is rough and contains hidden rocks and stumps, so the slip clutch on my RC gets a work out from time to time. Does this unit have slip clutch or shear pin to protect it? Or would I need to rely on raising unit to overcome these types of obstacles?
Also, please don't take this the wrong way, but the spindle on the 60" unit looks small compared to another pic of a 48" unit I saw elsewhere on this forum. What is the difference in cutters? /forums/images/graemlins/confused.gif
Lastly, does this unit discharge from both front and rear? Is the rear discharge a problem for the operator - seems kind of scarey with the operator facing into the discharge area - maybe an obstacle illusion on my part?
Thanks.
   / Finally used the Brush Cutter today #7
While the spindle looks small on the larger unit, the spindle on our PT425 48" brush cutter is just as small... about a 1" shaft. The difference is on ours the big round can attaches to the spindle, and then the blades attach to the can. On the 60" cutter as shown in theprevious posts appears to have a bar, instead of a can, that the blades are attached to. They still swing freely from pivot points like the ones attached to the can.
I have lost blades twice on my 48" cutter by hitting hidden rocks. The bolt head sheared off. The first time, the blade stayed under the unit. The second time, it flew forward about 10 feet.
The 48" unit is front discharge. This design is nice, because as you travel forward, most of the stuff is cut before the center of the spindle gets past it. Most of the stuff is discharged in a pattern to the front and right of the unit(may be left, I forget which way it rotates). However, chips and stuff will fly out in any direction, given the violent nature of the destruction going on under that beast. With the unit on the ground, anything that flies out the rear and doesn't go under the tractor will be stopped by the thick steel on the front of the tractor. As long as the operator is not hanging over the steering wheel trying to look down to see the rear of the brush hog, there is little chance they will be hit by flying debris. Too much steel in the way. I've had a brush hog on a conventional tractor, and just as much stuff came out in all directions as the PT unit, so I think that point is a tie.
I once hit a piece of hidden steel in tall grass. I flew out the back and shattered the left, rear wheel on the brush hog, then ricocheted forward out onto a highway. Thank goodness I had the sense to not mow with any cars around.
No sheer pins. No drive shaft to get caught in, either. /forums/images/graemlins/wink.gif
I believe the brush hog is the most dangerous piece of tractor equipment made. When used properly, it is a great tool, but it needs proper respect.
   / Finally used the Brush Cutter today #8
"I believe the brush hog is the most dangerous piece of tractor equipment made. When used properly, it is a great tool, but it needs proper respect. "
I don't think anyone will disagree with that. I've had sticks slung from my bush hog hit me in the back, before I put chains on the front of mine.
You PT owners sure are an enthusiastic group! /forums/images/graemlins/grin.gif I enjoy following the threads here too! Very cool machines!
I'm also considering the Ventrac too, but with 30K already in my current TN set up, hopefully I can find a good used PT or Ventrac for the auxillary mowing.
Mossroad just about explained the gist of it. It is a really great piece of equipment, you just have to be careful ( which I'm sure you already know). One thing I plan to do is add a strip of rubber to protect the front of the pt (and me). The front area gets filled up with branches and other debris from cutting. It can throw debris pretty good so I'm also planning on putting a Lexan windshield on too(also will help when snowblowing) As far as diameter goes, I cut down clusters of 2" trees easily. On the slightly larger ones, you may have to make a second pass. As long as you have sharp blades, it should cut grass alright, but not as nice as the finsih mower, of course. Once I get around to taking pics Ill post them, but I just might have before pics somewhere. ( I always for get to take pics when I use a new piece of equipment for the 1st time /forums/images/graemlins/grin.gif)
   / Finally used the Brush Cutter today #10
I don't know if Highridge's brush hog is a newer or older unit than mine. The one I have (abt 3 yrs old ) is built like mosses.Blades attached to the can, caster wheel brackets bolted to deck rather than welded and I don't have those reinforcement rods on the top.
I put a rubber guard on the back of mine also. I was more concerned with throwing stuff through the front tires than hitting me though.
Moss, is yours really closed in the rear? Seems like it would get hung up on stumps as the deck is lower thad the blades are cutting.
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
2017 Ford Expedition 4x4 SUV (A50324)
2017 Ford...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
(30) 9 Box Macro Bins (A50121)
(30) 9 Box Macro...
