Mowing Finish mower tires
   / Finish mower tires #1
Daryl
Southwest Virginia
New Holland TC30,, Kubota Bx2360
I have a New holland finish mower with tubeles tires. I seem to spend a lot of time putting the tire back on the rim. It seems anytime I get in rough or uneven terrain the tire comes off the rim. Anyone else have this problem or suggest a way to fix it. The tire has the proper air pressure.
Thanks
daryl
   / Finish mower tires #2
How about a picture of the tire and attachment on the finish mower (on or off the rim)? Some thoughts come to mind, but I need a better mental picture of your setup. Thanks
   / Finish mower tires #3
Hi,
Are you SURE it doesn't have a slow leak? Maybe the pressure is dropping as you use it.
Try checking the tire in a tub of water for a pin hole leak, or add some slime...
Just a thought...
Bill in Pgh, PA
I have put slime in the tires, I to thought that might be the problem. It has happened to both the back tires. What seems to be happening is on ground that is not smooth the tire sometimes gets pulled sideways and the "bead" is broken. I have thought about getting solid tires,but did not know if they would be any better.
Thanks
daryl
   / Finish mower tires #5
Maybe you could try tubes...if you can find a place that sells them in that small size they are pretty cheap.
But if the bead is coming off the rim, for whatever reason, then it might just pinch the tube and the end result would be the same...
Wonder what it would cost to get them foam filled? Probably more than a solid replacement I suppose...
Bill in Pgh, PA
   / Finish mower tires #6
Daryl, I went from solid to tubed tires over 15 years ago and would never go back. I really appreciate the softness they give to the mower's ride and think they reduce the wear and tear on the mower accordingly. I never have had trouble with them leaking, but maybe it's just the tubes doing their job. Have you pumped yours up to the maximum allowable pressure? This might keep the rims sealed better.
   / Finish mower tires #7
The tires should just spin around and follow your lead. Do they rotate freely 360 degrees on their support shafts? Not the axle shaft, but the shaft that mounts them to the deck. When you lift the deck they should just spin around with very little resistance. If they're stiff, try greasing them up, there should be some zerks on them. if they're still stiff, try removing the shafts clean 'em up real well and regrease. I had one on my 3ph Landpride mower that did that to me a couple of times until I cleaned the shaft with emery paper and regreased. No problems since.
I grease them every 2 or 3 times I use it. They do turn 360 when lifted. I guess maybe it is one of those things I will have to live with.
Thanks djradz. I have heard lots of negative remarks about solid tires. I guess I can just keep pumping them up.
Thanks
daryl
   / Finish mower tires #9
We sell a pile of Landpride finish mowers, and sometimes hear this complaint. There are usually two causes. 1. A lack of grease to the wheels' spindle, making it hard to caster.
2. Improper inflation. Landpride recommends 40PSI in its gauge wheels. What is the spec for your NH, and are you using a gauge to check pressure?
   / Finish mower tires #10
guys, is there general agreement that the solid tires on a finish mower are much less desirable? I dont have one yet but will buy soon. Need imput on the tires, thanks,brett w
   / Finish mower tires #11
Rick -- I have a LandPride FDR2572 and had that problem endlessly. It was really hard to inflate the darned thing when the valve stem is aimed at, and rests against, the hub! I finally got tired of dealing with it and had all four tires tubed and fitted with valve stems that turned 90 degrees so they could be reached with a pump.
I'm generally overjoyed with my LP implements, but the wheels on the finish mower was an example of the WORST sort of non-thinking engineering! If anyone else is in the market for a LP mower, check out the valve stems and demand they be retrofitted before making the purchase. When I complained after the sale LP told me the valve stems were "as designed," even though my dealer was unable to inflate them either.
Pete
   / Finish mower tires #12
One of my mowers is a Landpride AT2560 with pneumatic tires. First time out, one popped off the rim. It had gotten wedged at the edge of the grass/blacktop in a way that prevented it from rotating normally. I aired it back up, and haven't had any problems since. The deck probably has around 70+ hours on it now.................chim
I believe 40psi also. I gauge the best I can. I have the same problem Boondox has. The valve stem is turned into the hub. It is ver hard to inflate it much less gauge it. I grease them about every 2 times I mow. So I don't think that is the problem. The tire gets turned sideways in a turn or on uneven ground and breaks the bead.
Thanks
daryl
   / Finish mower tires #14
I usually wedge a screwdriver or something in behind mine to press them out a little fo filling and checking inflation. Seems to work OK.
   / Finish mower tires #15
I too have had a mower with solid tires and I won't go back either. The air tires give such a much better ride, the tractor/mower doesn't get banged around near as much when going over rough areas in my lawn. The only drawback to air tires like mentioned before is you want to make sure the air pressure is the same in all 4 so you get an even cut. I haven't had mine come off yet either. Mine swivel very easily on my First Choice mower. Does your mower float side to side as well as up and down. Maybe most of the mower weight is being transferred to one or two tires while turning on uneven ground and rolling the tires off if it isn't floating with the ground. The attachment points on mine allow for floating side to side which keeps the mower weight evenly distributed over all 4 tires. Just a thought.
Nick
   / Finish mower tires #16
i have a BEFCO rfm with inflated tires, never had one come off the rim, my old mower had solid tires and sometimes if i got into wet areas(mud) the mud would pop th tire off the rim. never happened with these tires. best i can tell u
   / Finish mower tires #17
forgot to mention, i don't have a problem geeting a gauge on them or inflating them, at least no more than trying to put a gauge on some of the new car tires/w3tcompact/icons/eyes.gif
   / Finish mower tires #18
I've had my Landpride finish mower for over a year and had been very happy with it. About 2 months ago, I started having the same problem. As each tire has gotten flat, I put a tube in. Yesterday a tubed tire went flat. I brought it to my farm supply store to check out if something was wrong with the tube. I'll pick it up later.
I thought I was the only one having this problem! I am seriously considering putting on solid tires, too.
I put Slime in mine to make sure they were not leaking air. I have a bottom area along a creek and everytime I mow in that area I break the bead on at least 1 tire. The area has a lot of ruts in it and I am sure this is part of the problem. Maybe on uneven ground the tire cannot turn correctly.
daryl
   / Finish mower tires #20
Thanks Daryl. After 4 years, two tractors and a couple hundred hours on my Landpride RFM with no tire problems. The tire jinx got me this past weekend. First I trashed a valve stem on one and after putting the new one in had one helluva time getting the lil sucker to reseat. Then the same tire broke the bead again after 20 minutes of cutting and that's when I noticed a small cut in the sidewall, so I had to once again break it down and patch it and go through the cussin all over again to get it seated.
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
2005 Peterbilt 387 with Wet Kit (A61306)
2005 Peterbilt 387...
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
John Deere 3025E (A53317)
John Deere 3025E...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
