Finish Mower
/ Finish Mower #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
I need some help here. I have a 25 HP Kioti tractor. My current finish mower is a Caroni imported by LMC I think. Its old and I messed it up. Could not get off one of the nuts to change blades. Tried a torch, liquidwrench, wax, everything. Finally tried angle grinder: I hit the threads. Totally ruined the bolt. So Im screwed. I thought about removing the piece that the bolt is in. Looks like I have to some how remove pulley that belt is on than drop bolt and its assemblydown through deck and I suppose order new part? Other choice new mower. Any thoughts on repair.
As far as new finish mower: Does brand really matter? My current mower is 60 inches. Advantage to going to a 6 foot.
Any help is appreciated
J
/ Finish Mower #2
If it is a Caroni, We have the new quill assembly that is shot on yours. We also have the top of the line "First Choice" 60 inch finish mower with solid tires for $1295 + shipping. Ken Sweet
/ Finish Mower #4
J
I have an LMC finish mower. The blade mounting bolts have LEFT HAND threads.
I am sure yours will be LHT as well---but I don't think that will help now:thumbsup:
/ Finish Mower
Quill assembly. I assume this is the housing that the pulley attaches to up top and below deck is a threaded bolt? Price? Easy to remove pulley without special tools??
/ Finish Mower #7
Caroni in Hospital:(
"no you did not mess it up; If you rolled it like my old hired hands the Geico wood chucks did after too many beers and pizza and folded it in half it would be messed up.
So Im screwed.
"no you are not screwed believe me"
"if you need a new arbor they are obtainble as may of them are a metric standard issue with hubs and bearings.
"The arbor is not damaged unless you cut it with the torch"
"It can be repaired successfully"
"the Caroni flail mower with the B rotor with 56 knives is stocked by agri supply but the finish rotor mower can be ordered"
"the factory is on vacation now and you could order one now and have it in early 2011 for mowing".
The F rotor has 4 rows of knives for 112 knives which has 28 blades per row.
"advantage"
"Only less time, spending money you dont need to spend, but no point in it as the old mower is fine".
"As long as your there ask them to change the oil in the gearbox if it uses one".
"No worries really, just a bit of time to repair it".
J
No worries about this at all:
Time and patience is all you need;
"If you Kioti dealer is nearby you can take it to them and with an hour or two of labor you will be back mowing shortly."
"No need for a new mower Dr. J, its fine as it is good for many more years of use."
"Just ask to have metric nylock nuts installed to replace the original metric nuts and yes they do make metric nylock nuts"
2022 EZ-GO ELITE...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2007 International 8600 Parts Truck (A63689)
2007 International...
Caterpillar Service Letters from 1960's (A63117)
Caterpillar...
Case SV280B (A60462)
