Finish mowing with Bush Hog
   / Finish mowing with Bush Hog #1
Bob77064
Elite Member
KY @ TN line
2011 LS R3039
Will a bush hog work as a finish mower? Some people have told me they have a rough cut mower that does a good job as a finish mower.
   / Finish mowing with Bush Hog #2
They must have a very bad finish mower with dull blades AND a Bush Hog with very sharp blades... :p
If you sharpen the blades and go slow, a bush hog can do a pretty good job but no where near a finish mower, IMO.
Are you trying this on good grass that's not too tall?
   / Finish mowing with Bush Hog #3
as was said by the previous poster.. maybee/ depending...
depending on the style of hog you have, and the distance from blades to ground with respect to the side guards ( IE, minimum cut height.. some light and medium duty units let you have a cut height as low as 2", whereas some HD mowers minimum cut height is mor e like 4", meaning you can't cut real close ).. , plus sharpening the blades, you can get 'close.
normally hog blades are only sharpened to about a 1/16 or a 1/32 blunt edge to 'shatter' brush, which kills it and leavs no sharp spears sticking up.. vs a finish mower made to clean cut and not shred grass.
if your hog is sharpened like a lawnmower blade, and can cut low, and you take your time to not gouge on the edges when turning, you can get a cut about as good as the cut form an ecomomy rider with 2 days of growth on it.
IE.. slightly shaggy 'finish' cut lawn.
soundguy
   / Finish mowing with Bush Hog #4
... also a finish mower typically will float & track to follow ground contours much better than the average rotary cutter, producing fewer gouges from edges or tailwheel, etc. with changes in slope, hillocks and dips.
Nick
   / Finish mowing with Bush Hog #5
If someone says they have a rough cut mower that cuts as good as a finish mower I'd have to think they were talking about a flail mower not a brush hog style mower....
Regards,
Chris
   / Finish mowing with Bush Hog #6
there are finish and rough flails as well.
soundguy
   / Finish mowing with Bush Hog #7
Nahhhh ! I'm not buying it...a bush hog, rotary cutter, shredder - whatever you want to call it is not a finish mower...and will not ever give as fine and low a cut as a finish mower unless you have a finish mower with awful blades...Now, I may be wrong so if anyone wants to bring their bush hog to my place and cut all my pastures ...I will take a look when they are all cut and see if I agree...Maybe I am wrong...so come on and we will see...:thumbsup::laughing:
   / Finish mowing with Bush Hog #8
Like many questions, it depends.
Question number one is your definition of "lawn"- a putting green ain't the same as my lawn that used to be pasture, and contains several grass varieties, plus some lambs quarters, dandelion,vetch, mullion, clover, and plenty of crabgrass. But is all green, and stays that way, flood or drought, for most of the year. Near the house I use a 'lawn mower', and the meadow gets cut a few times a year with an old bush hog. From a few hundred feet away, you can't tell the difference.
If I wanted that golf green look, I would use an old push reel mower; there's nothing like the quiet "snick snick" that doesn't compete with the bird and the frogs.
   / Finish mowing with Bush Hog #9
It realy DOES depend on alot of variables.
I have a older 'red' LD 5' kk that will cut down to 2" I have many times sharpened her up and put a set of depth limit and stabilizer chains on her and mowed my front yard.. again.. it gives you a lil rougher cut than a cheap rider.. Does NOT cut as good as a clean push mower. Again.. at 30' way.. it looks close enough to not know what mowed it.
my buddy has a hd 6' KK that is a year old or so. the side boards on it are 6" he can't cut any closer than 4" off the ground.. thus his WILL NOT make any sort of close cut no matter what.
lots of variables...
soundguy
Thanks for all the help.
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
Tank Only (A59076)
Tank Only (A59076)
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
