I have some stripped alder here. It isn't worth the fuel to cut it for firewood. Once it's dry, there is nothing to it. May as well burn a wadded-up newspaper. :laughing: Cut or chipped, I just don't see the alder I have as worth hauling.
Standing firewood trees here will bring $20-$25 per cord for the owner. Adjusted for your prices of course, the trees are worth $20/cord and all you need is a pen to sign the contract. So, even that portion isn't "free", you are consuming an asset that has value. Delivered as logs, they bring about $100 this year. For transport to your house, the $80 difference is where you can try to find savings. In relative numbers, it isn't really a question of "can you do it for $100?" You would need to beat $80 for it to make economic sense.
In the first video, the owner mentioned that hauling chips is less economical than hauling logs, I guess because they take more space volume per ton. Makes sense, so you would want to transport logs, not chips. The easiest log hauling would be a straight truck with a grapple. That gives you a grapple at each end of the operation. You still need a way to skid the tree to the truck.
How do your log sizes compare to affordable
chipper sizes? For how many years can you harvest the required number of that size (or less) log?
Having the
chipper at home is probably a benefit in terms of ease of maintenance and security. They do make a racket that could put close neighbors on the war path. It seems like a set-up where you blow chips into storage bin or shed would be good if you feed the boiler from that bin or shed directly.
I think it adds up to a lot of costs and labor. Whatever money you get tied up in depreciating equipment is foregoing earnings too.
