First BX23 project
   / First BX23 project #11
Nice looking machine.
I spent many hours spreading gravel with my 3010 and FEL. Last year I had a few truckloads delivered and was moving it around with the FEL. I happened to have the box blade attached, so I gave it a try.
Incredible - especially if you are spreading the pile around. Basically I lift the box blade, back up as far up the pile as I can go, drop it and drive in the general direction of spread, slowly lifting the 3PH as I go.
Much faster, because you don't have to drive in, lift the FEL, back out, turn around, etc.
   / First BX23 project #12
As someone already indicated, "how" you use the 'hoe makes a difference. You can't depend upon brute-force with the BX22/BX-23 'hoe. It's a great tool, but you need to work it around a bit and actually dig things out, rather than rip them out like you often can with a big machine. You also have to learn to go a little slower as the hydraulics are not as strong as a larger machine.
If most of the work you need to do is much heavier duty and will be continuous into the future, maybe an upgrade is warranted. But if they are temporary, rent a bigger machine for those particular jobs and use the BX for normal maintenance and smaller projects. After all, it's a lot more maneuverable than big machines and can get into places you can't if you up-size much at all.
   / First BX23 project #13
</font><font color="blue" class="small">( She's half Australian sheperd, half pointer, or so that is what they told me at the pound. She's a real good dog. )</font>
I think that what they meant was she is part Australian cattle dog, also called a Blue Heeler. Great dog breed.
Jaycee
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
2009 FREIGHTLINER CASCADIA SLEEPER (A51222)
2009 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
