First CHoice mower leaving uncut streaks
   / First CHoice mower leaving uncut streaks #11
Do you cut your grass in an arcing pattern or do you cut in straight rows. Every multi-blade mower with offset (non-overlapping) blades has a small range of radii where the mower will miss the strip between the true distance between the baldes (1/4 in your case). The test for this is to compare your cuttings results while traveling in a straight line with your cutting results while traveling in an arc.
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2007 Volvo VNL Truck Tractor (A52748)
2007 Volvo VNL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
