First CHoice mower leaving uncut streaks
   / First CHoice mower leaving uncut streaks #11
Do you cut your grass in an arcing pattern or do you cut in straight rows. Every multi-blade mower with offset (non-overlapping) blades has a small range of radii where the mower will miss the strip between the true distance between the baldes (1/4 in your case). The test for this is to compare your cuttings results while traveling in a straight line with your cutting results while traveling in an arc.
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
