First oil change BEFORE recommended time interval
   / First oil change BEFORE recommended time interval #11
I would like to see on tractors- what they have in most cars now. The display that tells you what "%" of oil lubricity is left, or the "change oil" light.
I have had a time convincing my wife that "every 3000 miles" is a waste, when the manufacturer has given you a tool that better suits the engine.
-for those not familiar, being computer controlled, the cars system calculates oil life based on several factors. Engine RPM, Temperature extremes and other factors that breakdown oil. It is not simply a 'count down" clock.
Since there are many different things each of us do with our tractor, it would be individualized when we do the P.M.
With my tractor, I follow (the best I can) the recommended intervals. However, with the average of 50 hours per year that I put on, I opt to do P.M. annually.
Ironically, I am about to get the oil changed in my car. 10000 since the last one, getting the same MPG all the time!
   / First oil change BEFORE recommended time interval #12
From what I understand, the filter is the weak link.
-- in general -- not neccesarily tractors --
If you change the filter, your oil can go the distance. Most just figure on changing the oil "while their at it".
Don't tractor trailer operators change their filters but keep their oil and have analysis done on it? They have A LOT of oil to change... so it make sense in their case.
   / First oil change BEFORE recommended time interval #13
I knew a farmer when I was about 16 that I sometimes drove his 806 IH tractor that only changed the filter and never the oil. IT used about 2-3 quarts per day when under heavy load which was about typical of diesel tractors back in the 60's. He just kept pouring the oil in daily and changed the filter (ocassionally). He had 2 of the 806 tractors and they had close to 10,000 hours on them last I remember and they still ran just like they did when new. They used about 1-3 quarts of oil per day depending on the severity of service. Air filters were cleaned and replaced regularly, but I know that in 3 years, the oil was never changed, well make that drained and refilled. It was changed 3 quarts at a time.
   / First oil change BEFORE recommended time interval #14
the OP problems would come from condensation and dry start from very low useage.he would be better off starting & running tractor once a week than letting it sit and changing at 25 hrs
   / First oil change BEFORE recommended time interval #15
One reason to wait (I didn't see this in any of the previous posts, surprisingly, but I may have missed it) for the 50 hours is the engine break-in. Piston rings need to wear in to ensure a good seal and long life.
So, I'd go the 50 hours, even if you make time or tasks to use the tractor.
When I bought my old 790, it had 24 hours on the meter (even though it had been owned by the previous owner for about a year or a bit more). The dealer I bought it from was pretty insistent I wait until 50 hours before the first oil change. I did, but I made sure I had those hours accumulated within a few months.
After break in, I change annually regardless of how few hours I put on the machine (I average 75 hours annually).
   / First oil change BEFORE recommended time interval #16
Low use owners are tempted to "start up" their tractors once a week or so, but the problem with that is that many might not do anything more than idle it for a few minutes, then shut it down.
Frankly, I'd much rather have the equipment sit as to do that to it. There is no point in starting up a machine until or unless one has actual work for it to do. Those cold starts and warm at best shutdowns are brutal. Idling itself accomplish very little and can do more much more harm than good.
   / First oil change BEFORE recommended time interval #17
I guess I am from the old, old school when you changed the oil the first time on a NEW engine after a short running time. Remember when car manufacturers recommended 1st change at 1000 miles and then each 2000 miles thereafter. Just purchased a high $ zero turn mower and the manufacturer recommended the 1st change after 8 hours and then each 100 hours thereafter. In manufacturing there is usually some metal particles, dirt, etc left inside the engine block. The first oil change will get rid of it. After the 1st change follow the manufacturer recommendation.
Regards, Gil
   / First oil change BEFORE recommended time interval #18
I dont know if the manufacturers still do it, but years ago the break-in oil was different from the recommended oil. If I recall, most of it was a straight mineral oil with out the detergents to keep the engine clean. They wanted it to wear in a bit and build up some deposits, therefore they had a short time between oil change. I dont think that a modern engine builder today would have dirt etc left in the engine after assembly what with the clean rooms and such that they use, unless they are still working in the old chinese factorys with the dirt floors. What you do get is the wear forming of all the bearings that produces the small amount of metal as I mentioned in post #10 and this is a very small amount. We get rid of that and get a top quality oil in the engine after the break-in period to reduce any further wear to a minimum. I would agree with Roy that if you dont complete the breakin period prior to changing the oil, then you may do more harm than good to your engine. If a person cant put 50 hours on a tractor in a year, then he likely didnt need it to begin with. My tractor will set idle for 2 months while I am out of the country working, but I will put 30-40 hours on it in the 3 weeks I am home just about everytime. Of course I am still trying to get all my place in shape so there is lots of bush hogging and dirt moving to be done. The hours will likely fall way off once I get most of the planned projects completed.
   / First oil change BEFORE recommended time interval #19
The vast majority of engine builders today no longer use anything remotely similar to break-in oil. GM, Ford, Chrysler, etc in the their cars and trucks do not and have not for decades. Standard 5w-30 or whatever, nothing special.
Shoot, you have a large and increasing number of vehicles, "foreign" and "domestic" that come with full synthetic in them from the factory. Wow! how do they "break-in"? The tolerances and metallurgy is so changed, that there isn't much to break-in anymore, not as we understood it in the past.
Times and technologies change.
   / First oil change BEFORE recommended time interval #20
There's another reason to wait, When an engine block is machined there are stray particles of metal floating around that suspend in the oil and lay on the bottom of the crank case. Sometimes it takes time, even a little engine and machine bouncing around, for them to migrate to the filters.
Like others have said it won't do any harm but the benefit is questionable. I'd let it sit and change it out at 50.
If you want to do something good for your engine when you do the first oil change drill a small hole in the drain plug for a 1/4" high power magnet. We used to do this on our racing engines and I think Porsche still does it for all their production models too.
By the way, the most wear on an engine is when it starts and stops, especially if it has been sitting for a few weeks. If you start it get it hot, few things kill an engine as fast as the person who drives three miles to work and back. The engine never gets hot enough, that's bad.
Rob
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
207276 (A52708)
207276 (A52708)
