First post, smallest tractor for 5' brush hog?
   / First post, smallest tractor for 5' brush hog? #1
broncosfan
USA
Tractor Shopping
First post here, I am trying to find what is the smallest tractor that can run a light duty 5 foot brush-hog/rotary mower for pasture grass? What's the smallest new deere and Kubota that can do this? I only know the deere 2305 and BX2350 are out of the question. Thanks in advance.
   / First post, smallest tractor for 5' brush hog? #2
Don't know about others but Kioti CK20 will run a 5 ft brushhog and 5 ft box blade. I have been using this setup for 6 months with no harm to tractor or me. hope this helps. :)
   / First post, smallest tractor for 5' brush hog? #3
I don't know that a 2305 is out of the question, though it would be smallish.
Basic rule of thumb is 5 PTO hp per foot, so 25 PTO hp in your case. Pasture grass is generally not the most difficult thing to cut so you wouldn't need too much over that, unless you have truly lush pastures of some tough grass (bromegrass, really tall fescue, some southern grasses I don't know much about). Something like a Kubota B7800, Deere 2320 or 3120, various other models in that range would probably work fine.
Any other tasks for the tractor? That will be important too.
   / First post, smallest tractor for 5' brush hog? #4
A Kubota B7510.
I bought my 5' cutter from a Kubota dealer who also sold Land Pride. I had a 16.5 HP Deere 670 based upon the dealer's assertion that they sold these 60" standard duty cutters to B7500 owners. Powerwise, the B7500 and 670 were very close.
Land Pride recommended 20 PTO HP minimum (4 HP per foot) and I was running it with 16.5 HP which is about 3½ HP per foot (the B7500 was about the same PTO HP).
The 670 did a fine job, so I think it's safe to assume the B7500 (now B7510) would do well too...at least as far as brush cutting.
The hindrance with the B7500 or B7510 might be the weight of the cutter if you wanted to transport with it raised. I could with my 670 (as long as the FEL was installed), but the 670 weighed a few hundred pounds more then the B7500. However, even with the 670 (and my current 790), I towed the cutter more often then transported it raised. This isn't something you'd want to do any great distance though.
Anyway...the question was what is the smallest tractor that can run a 5' cutter. Well, the Kubota B7500 is the machine.
That's if we're talking new tractors. Used Deeres would be the 755, 855, 670 and 770. The pictures attached show the 5' Land Pride rigged to the 670.
I don't know where the 5 HP per foot number came from...I think it's one of those internet suggestions that eventually became "fact".
   / First post, smallest tractor for 5' brush hog? #5
As for Kubota... I would say a B7510DT (17 PTO HP) would be about the least I'd go with. A more comfortable fit would be a B7800.
   / First post, smallest tractor for 5' brush hog? #6
Broncosfan:
Welcome to TBN :D! As usual I agree with Roy. I have no clue as to origin of the "5HP per Foot Rule" either, but I have tended to follow the "Rule". My 23+HP PTO handles my 60" medium duty RC without difficulty and I have cut some nasty stuff including softwood saplings (poplar) in the +1.5" range. I got interested in the evolution of this rule and I did find this information in "The Compact Tractor Bible"- "The power (required) is typically 2 horsepower per foot of cut for light-duty rotary mowing and 5 horsepower per foot of cut for brush hogs capable of smashing 2-inch-diameter saplings. Hope this helps- Jay
   / First post, smallest tractor for 5' brush hog? #7
Other than the PTO HP requirement you would want to consider the weight of the tractor. The 5' ft. Brush Hog can be a big heavy tail. The momentum of the blades will cause the tractor to vibrate more. If you have hills then the weight of the brush hog may make the tractor too light in the front end.
If you get a light tractor you may want to consider a light cutter. Or you may have to add some weights to the front end to keep things manageable.
Just another issue that is often over looked.
PB
   / First post, smallest tractor for 5' brush hog? #8
PBinWA:
I agree. I leave my FEL on (and low) for balance as well as to knock stuff over and find an/or carry things. Jay
   / First post, smallest tractor for 5' brush hog? #9
JD suggests 790, 990, 2520 and up in the 20 series, 4210 and up in the 10 series (and I would assume 4200 and up in the earlier 4000 series). The LX5 was rated at min 18 hp, Frontier light duty 60" at 20 hp
   / First post, smallest tractor for 5' brush hog? #10
It isn't hp; it's weight you have to watch for. A friend of mine ran a 5' brush hog with a 16 hp Kubota. He said he needed to put suitcase weights on the front, as he didn't have a FEL.
The 2310 and 4010 take the same implements. They're both the same weight, but the 4010 only has 18.5 hp vs. 23 or so in the 2310. My 4010 would drive a 5' hog long if I didn't have to horse it around too much on hills; be a bit too much weight back there on some situations on hills.
Ralph
2010 Ford Transit Connect Van, VIN # NM0LS6AN8AT009921 (A44391)
2010 Ford Transit...
John Deere Pull-Behind Dry Fertilizer Spreader (A44571)
John Deere...
2006 HINO 268 24FT REEFER BOX TRUCK (A43004)
2006 HINO 268 24FT...
2005 International 9900i Truck, VIN # 3HSCHAPR75N150824 (A44391)
2005 International...
Whiskey Barrel (A44391)
Whiskey Barrel...
2017 GMC Sierra Pickup Truck, VIN # 1GTR1MEC6HZ115515 (A44391)
2017 GMC Sierra...
