First Tractor Ford 1700
   / First Tractor Ford 1700 #11
Trapper,
welcome to TBN Blue, you got great little tractor that is more capable that your intended tasks. I have several posts about this tractor that should give you plenty of info. Use the forum's search engine for "Ford 1700" or "Jc-jetro" and you'll have many hours of gooood reading ahead of you. let us know if you have questions about how to search. Glad you got ROPS.
JC,
ps. By the way I use Rotella from TSC same weight that you mentioned and used Mystick (tsc) brand and thats just fine. There are several grade Mystick , make sure it is Ford-134 compatible.
JC
I have a question about changing oil in the fuel injector pump. How do you remove the fill plug/breather cap off to put in new oil? The breather cap does not screw off--it just spins. I have tried pulling it up and twisting it, but it does not screw off. Thanks for your help.
P.S I am new to the forum and have not figured out how to post a new question.
Ken
   / First Tractor Ford 1700 #12
Ken,
I just saw this thread. I did respond to you on another thread also. You need to loosen the 10 mm bolt just below the cap.
JC,
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
