Fix front winch
/ Fix front winch #2
With 10,000# line pull you might seriously damage your tractor which only weights 3,000 pounds.
Unless your tractor was chained to a very big tree you could never develop 10,000# line pull. Your tractor would just be sliding across the pavement.
What are you trying to do with the winch?
Dave M7040
/ Fix front winch #3
With 10,000# line pull you might seriously damage your tractor which only weights 3,000 pounds. Unless your tractor was chained to a very big tree you could never develop 10,000# line pull. Your tractor would just be sliding across the pavement. What are you trying to do with the winch? Dave M7040
It would drag the tractor around long before damage resulted assuming the attachment point was adequate. Unless of course he chained to to a tree or rammed the FEL into the ground. What's the intended use? It'll pull pretty slow. You may be better off going with a 3 point hitch PTO driven skidding winch. I didn't see a price on the hydraulic winch, but I'm guessing it's over $1000 USD and you still have to get a hydraulic hook up.
/ Fix front winch #4
I've seen plenty of PTO winches and hydraulic winches on vehicles but not a hydraulic winch on a tractor. The vehicle mounted ones I've seen run off the PS pump.
This seems like a fairly straight forward project. I'd assume you could use a 3rd function setup and QC the fittings into the winch when needed.
/ Fix front winch #5
$799 US, shipped from Canada or $999 if bought in Canada. Probably cheaper if bought in China.
/ Fix front winch #6
I have a 10,000 lb. Warn electric winch on the front of my tractor to be used as a backup, or when I can't get in a position to use the PTO driven Farmi winch. It has already paid for itself when my Farmi had to be serviced because of a defective clutch. Only problem is that the Warn is slowwww. But it served it's purpose as a backup and I was able to continue skidding with my Quick Hitch and chokers.
/ Fix front winch
The goal is:
Using it occasionnaly to remove some tree far from my road. When is happen I don't want to remove the snow blower or the backoe from the back of tractor for one tree.
Having it full time on the tractor help on other occasion (if I'm stuck by example)
With an hydraulic one it will be faster and stonger then an electric one.
And don't forget that 10000 lbs is the rating at the max flow with all the wire out of the drum. In reality it vary from 4000 to 10000lbs. So just perfect for the purpose.
Also I can probably use fhe loader as an fix point if holding power is too strong.
Last, it will be cheaper then buying a new real forest winch.
/ Fix front winch #8
Costco sells the same winch for $800, was considering buying one for the tractor, but think compared to a skidding winch it would be too slow and not enough cable for my needs. For occasional use it would work well and may be something worth trying.
/ Fix front winch #9
The goal is: Using it occasionnaly to remove some tree far from my road. When is happen I don't want to remove the snow blower or the backoe from the back of tractor for one tree. Having it full time on the tractor help on other occasion (if I'm stuck by example) With an hydraulic one it will be faster and stonger then an electric one. And don't forget that 10000 lbs is the rating at the max flow with all the wire out of the drum. In reality it vary from 4000 to 10000lbs. So just perfect for the purpose. Also I can probably use fhe loader as an fix point if holding power is too strong. Last, it will be cheaper then buying a new real forest winch.
I would not recommend doing that. That's a great way to break something. The loader was designed to take the push of the tractor and not much more. A 10000 pounds is many times stronger than what the tractor could push.
/ Fix front winch #10
Thanks for that, I'll have to find someone who's a member.:thumbsup: They also give a pulley block with theirs. Here's the cosco link for it. It also say's shipping and handling included, not bad.
Runva 1HX 4535.9 kg (1, lb.) Hydraulic Steel Cable Recovery Winch
/ Fix front winch
Thanks for the link, direct from China the cost is $500 US, I'm not sure that it's worth buying direct, unless buying a larger quantity!!!
Also after review all the comments the following model is probably a better fit: HWD8000.
HWD8--Runva Winch
It's faster (It had 2 speed) and less strong (between 2000lbs and 8000lbs). I have to check about pricing!
/ Fix front winch #12
jcmaurice6
The easiest way to mount would be a quick attach plate with a 2" receiver tube. Then you would just mount the winch to a winch mount receiver plate that slides in.
/ Fix front winch #13
Or maybe a pair of receivers, to spread the load on the bucket. It would be convenient to be able to remove it as well.
/ Fix front winch #14
Personally, I don't think attaching this winch to a quick attach or anything that the loader arms would carry the load would be a good idea. The stress on the loader arms could be compromised, in my opinion. The frame would be the strongest point of attachment in my opinion.
/ Fix front winch #15
$500, China....mmmm....then you'd have to add shipping, duty and taxes. I would go with Costco, I found a member and may just purchase this one. ( the first one you posted ). My plan is to add it to the dipper on my backhoe. I would be able to lower the boom or angle it accordingly. I use to own my own towing service company and I think this winch would just be perfect for my need's. Although I really don't know what that need is...lol, but if I ever need to call upon it, it's there.:p
/ Fix front winch #17
I've owned a Milemarker 2spd hydraulic winch. Extremely durable and dependable. Extremely slow in low gear. Extremely weak in high speed.
A hydraulic winch is generally slow. Much slower than electric.
I think the chart linked above is in error. It shows fastest speed at heaviest pull load???
Anyway, assuming it's accurate, 10 ft/min as it's fastest line speed.... Get yourself a clock and time a minute. While you are ticking off your minute look for something 10ft away. You'll have plenty of time to find something to use as a distance mark. Now apply this to work situations. Is that acceptable????
I have two electric winches with max line speed in excess of 60 ft/min. That adjusts with load of course. At their maximum load they easily exceed 10 ft/min.
If using a hydraulic winch patience is a necessity. :)
/ Fix front winch #18
I've owned a Milemarker 2spd hydraulic winch. Extremely durable and dependable. Extremely slow in low gear. Extremely weak in high speed. A hydraulic winch is generally slow. Much slower than electric. I think the chart linked above is in error. It shows fastest speed at heaviest pull load??? Anyway, assuming it's accurate, 10 ft/min as it's fastest line speed.... Get yourself a clock and time a minute. While you are ticking off your minute look for something 10ft away. You'll have plenty of time to find something to use as a distance mark. Now apply this to work situations. Is that acceptable???? I have two electric winches with max line speed in excess of 60 ft/min. That adjusts with load of course. At their maximum load they easily exceed 10 ft/min. If using a hydraulic winch patience is a necessity. :)
It's actually 20fpm at 10 gpm hydraulic flow. His tractor only makes 6 gpm hydraulic flow so it will pull slower.
/ Fix front winch #19
Thanks for the correction, I totally misread. Didn't address the tractor gpm as a slowing factor. Thanks.
/ Fix front winch #20
And what pressure does his tractor put out and what pressure does the winch max out at?
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
74 Gallon Delta Fuel Cell with Tool Box (A61166)
74 Gallon Delta...
(2) UNUSED 17.5L-24 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED...
DRESSER GALION 712 TANDEM ROLLER (A62129)
DRESSER GALION 712...
2023 Ferris ISX 3300 Zero Turn Mower (A61166)
2023 Ferris ISX...
UNUSED WOLVERINE MPF-11-2500G MINI PALLET FORKS (A62131)
UNUSED WOLVERINE...
