Flat Tires
   / Flat Tires #1
JAE 3400
Bronze Member
Ashtabula Ohio
Kubota L 3400
Greetings All, I am tired of fixing flat tires on my RMM. It is a Landpride FDR 1572. Does anyone know of a source for a solid rubber replacement tire for this mower? I thank you in advance.
   / Flat Tires #2
my local tire and weld shop placed thick rubber liners inside my tractor tires and reduced puncture flats on my Case VAC to zero.
just curious, what is the source/cause of your tire flats?
   / Flat Tires #3
You could ask your local tire store about foam filling tires, it is pricy but they won't go flat. Another down side to foam filling is it makes tires heavy.
   / Flat Tires #4
Land pride sells solid tires for their mowers... unfortunately they also sell the replacement yokes for the solid tires, you can't use the ones you have. co$t is up there... KennyV
My landpride FDR2584 has the tires foam filled... Works great
   / Flat Tires #5
Get the tire foam filled
Something that small won't be much at all.
you can get ultra-light foam which is a lot lighter than the regular foam.
Stuff is worth every penny.
when the tire gets worn out, you just have the tire recapped.
   / Flat Tires #6
Foam is the only way to go.
I find it cost effective even on large 4wd tractor front tires.
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
