Flat Tires
/ Flat Tires #1
JAE 3400
Ashtabula Ohio
Kubota L 3400
Greetings All, I am tired of fixing flat tires on my RMM. It is a Landpride FDR 1572. Does anyone know of a source for a solid rubber replacement tire for this mower? I thank you in advance.
/ Flat Tires #2
my local tire and weld shop placed thick rubber liners inside my tractor tires and reduced puncture flats on my Case VAC to zero.
just curious, what is the source/cause of your tire flats?
/ Flat Tires #3
You could ask your local tire store about foam filling tires, it is pricy but they won't go flat. Another down side to foam filling is it makes tires heavy.
/ Flat Tires #4
Land pride sells solid tires for their mowers... unfortunately they also sell the replacement yokes for the solid tires, you can't use the ones you have. co$t is up there... KennyV
My landpride FDR2584 has the tires foam filled... Works great
/ Flat Tires #5
Get the tire foam filled
Something that small won't be much at all.
you can get ultra-light foam which is a lot lighter than the regular foam.
Stuff is worth every penny.
when the tire gets worn out, you just have the tire recapped.
/ Flat Tires #6
Foam is the only way to go.
I find it cost effective even on large 4wd tractor front tires.
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
18' Utility Trailer (A64047)
18' Utility...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2018 HINO SA (A58214)
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2021 LIUGONG 925E EXCAVATOR(INOPERABLE) (A63569)
2021 LIUGONG 925E...
