Flat Tires
/ Flat Tires #1
JAE 3400
Ashtabula Ohio
Kubota L 3400
Greetings All, I am tired of fixing flat tires on my RMM. It is a Landpride FDR 1572. Does anyone know of a source for a solid rubber replacement tire for this mower? I thank you in advance.
/ Flat Tires #2
my local tire and weld shop placed thick rubber liners inside my tractor tires and reduced puncture flats on my Case VAC to zero.
just curious, what is the source/cause of your tire flats?
/ Flat Tires #3
You could ask your local tire store about foam filling tires, it is pricy but they won't go flat. Another down side to foam filling is it makes tires heavy.
/ Flat Tires #4
Land pride sells solid tires for their mowers... unfortunately they also sell the replacement yokes for the solid tires, you can't use the ones you have. co$t is up there... KennyV
My landpride FDR2584 has the tires foam filled... Works great
/ Flat Tires #5
Get the tire foam filled
Something that small won't be much at all.
you can get ultra-light foam which is a lot lighter than the regular foam.
Stuff is worth every penny.
when the tire gets worn out, you just have the tire recapped.
/ Flat Tires #6
Foam is the only way to go.
I find it cost effective even on large 4wd tractor front tires.
Lastec 120ER Articulating Turf Mower (A64047)
Lastec 120ER...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
John Deere 612 2-Bottom Plow (A63116)
John Deere 612...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
240156 (A56859)
240156 (A56859)
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
