Float Position on LA243 FEL
   / Float Position on LA243 FEL #11
   / Float Position on LA243 FEL #12
For me float seems to work best when back dragging. I usually get better results not using it and just controlling the down pressure myself.
   / Float Position on LA243 FEL #13
Ran out to the barn and tried it. Had to push hard, but it does indeed go up another notch.:eek: Thanks for the tips on engaging it off the ground until getting the hang of it.
Almost everyone seems to have trouble figuring out their float for the first time. I think it took me a year - tried if a few times...didn't think it worked. When I finally really needed it I figured it out. The dealers need to explain this better to new owners.
   / Float Position on LA243 FEL #14
When you get skilled with float you can use it to scoop up material for example a dile of dirt, stone or gravel that you need to move from on area to another.
1) As you drop the bucket down engage float just prior to the bucket hitting the ground [MAKE SURE THE BUCKET IS EITHER LEVEL OR CURLED UP A BIT. IF you engage float with the bucket curled down you will dig in and things can get nasty]
2) once the bucket is on the ground and level now you can pop the joystick back [disengaging float] and you have now quickily and accurately set your bucket level to the ground.
3) As the bucket enters into the pile of material you can now gradually raise the bucket.
If you do not use float in this process you risk pushing the bucket too far down and potentially taking presure off your front wheels
   / Float Position on LA243 FEL #15
I have used six tractors over the years from 22 to 80 hp as well as a backhoe and never felt I needed to use "float", but will give it a try, thanks.
   / Float Position on LA243 FEL #16
I think you are in for a welcome suprise...
Thanks for all the tips/advice. Tried some of these already and I see the value of float now.
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
Torro Groundmaster 3280D Riding Mower (A59814)
Torro Groundmaster...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
