crashz
Veteran Member
I was hoping you guys could point me in the right direction here. I've been doing a little welding on my snow plow, fixing cracks and reinforcing patches.
I use a 120V/240V Hobart Handler 210 on 120V single phase and flux core wire. Typically Hobart brand 0.030 flux core wire used. To weld 1/4" mild steel, I really need to plug the welder into any outlet directly, and still sometimes pop the breaker. This places the welder close to a wall in my garage and limits my mobility, which OK fine for now.
I find that the leads are long enough to do my work, but my welding angles and the loop of the working cable can get tight bends. And that's when it seems like the flux core will break in the machine, right at the drive wheel. If I tighten it it seems to break more, if I loosen it the wire just stops feeding and balls up. The sweet spot drive wheel adjustment is at ~3-4. I thought changing the tips made a difference, but it there is no consistency between worn or new tips. I tried a new feed cable too, with no difference.
Any thoughts? Long term I think I need to upgrade the garage outlet (which will be very easy) and get a stick machine to do the heavy work. Sheet metal should still be done with the the wire feed, so should I try solid wire and gas?
