flywheel bolt installation on 1972 Ford 2000 tractor
   / flywheel bolt installation on 1972 Ford 2000 tractor #1
kennyl123
Bronze Member
Pollock, LA
Ford 2000
Hi guys, I have installed flywheel to crank 3 times and 4 bolts go right in but can not get the other 2 to start. What am I doing wrong? Is there a way to tell how to line up bolts and holes?
   / flywheel bolt installation on 1972 Ford 2000 tractor #2
Usually the bolts are indexed slighty off from one another, it will only go on the crank one way. Its not much and you may not even see it but its a common thing.
   / flywheel bolt installation on 1972 Ford 2000 tractor #3
Ding Ding! Winner! You have 6 choices. One will work. When I remove a flywheel, I prick punch the O.D of the flywheel at the top where it sits. If I don't rotate the engine and use a 9/16 NF dowel in the top hole of the crank, the indexed flywheel goes on the supporting dowel correctly the first try.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
UNUSED JCT 72" VIBRATORY PLATE COMPACTOR (A51248)
UNUSED JCT 72"...
2010 CATERPILLAR 140M MOTOR GRADER (A51246)
2010 CATERPILLAR...
2015 INTERNATIONAL PROSTAR (A53843)
2015 INTERNATIONAL...
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
aerator (A52377)
aerator (A52377)
