FMC brushcutter and ???
   / FMC brushcutter and ??? #1
kenstrac
Platinum Member, RIP
So central NH.
Kioti DK 45
Many years ago I went to an auction and they had a FMC brush cutter that was powered by the PTO to a tire then to a round disk just below the deck (no gear box) ,also on my travels I ran across a what I call a large string trimmer, It had a hyd pump on the PTO which ran a hyd motor on the motor was attached a round plate that had instead of string were using old v belts and was offset to the right side of tractor.
My question is has anybody seen or owned any of these ,and if so what was your experience with them.
Any Pictures?
   / FMC brushcutter and ??? #2
Any Pictures?
Here's a picture of bush hog that is driven by a wheel, which itself is driven by the PTO shaft. It's not a good picture but you can get the idea. If you look real close, you can just barely see the edge of tire sticking out a little bit in front of the top part of the shroud.
The good part about this wheel driven set up was that it acted as it's own slip clutch when the wheel slipped on the round plate, whenver you hit something hard. Interesting design.
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
