For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool?
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #1
dirt ditch
Platinum Member
I can not find any online reference to the diameter of a 10 pound spool of wire. So am I correct in assuming that a 10 pound spool of .035 Lincoln Innershield NR-211-MP is 8 inches in diameter?
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #2
From my search it seems to be on a standard spool. What is your concern?
I just want to know the diameter of a 10 pound spool of wire.
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #4
Around 10-3/4" for the standard spool.
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #5
There are some slight variations, but typically -
4" spool, solid wire - steel, 2 lbs. Aluminum - 1 lb.
8" spool, solid wire - steel, 10-12 lbs.
12" spool - plastic spool, solid steel - 33 lbs. Steel wire frame spool, up to 44 lbs.
I don't use flux core, but it would weigh slightly less. HTH... Steve
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #6
8" is the standard size for bench top MIG welder spools. Lincoln also has 14lb ready reels of their wire but they use a different adaptor.
Thanks for the replies. A 10 lb spool is what I will get. I stumbled across Hobart's spool explanation page and found this info.
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
John Deere (A50322)
John Deere (A50322)
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
72In FEL HD Round Back Bucket (A52748)
72In FEL HD Round...
