hgd1956
Hey........I just saw this thread and I had the same type problem with my 1700. The basket case tractor would not steer at all due to the horizontal shaft being broken at the end where the adjustment screw attached. I managed to find one on ebay that fit for less than 200 dollars instead of the 600 new holland price. Assembled it and still had loads of slop, Had to pull the vertical steering shaft and found that the lower bearing was toast, not there. replaced both upper and lower bearings and the thing will at least go through a gate without taking out one of the post. Still has some slop but it is due to excessive wear in the front end. I will fix that later. Wish I had seem this posting earlier since I had already gone through most of your problems..............
