Ford 1510 Hydraulic Fluid level
   / Ford 1510 Hydraulic Fluid level #1
gschones
Oklahoma City.OK
John Deere 1205R
I recently had to replace a lower line and decided to changed the hydraulic fluid in my Ford 1510. I put 19 quarts of fluid in as recommended by others on this forum and my data. However it did not register on the dipstick. So I added the remaining quart left in the 5 gallon bucket and it just barely came up to the bottom of the dipstick. It was registering before I changed the fluid. I am thinking about adding another quart or so to bring up the level. I don't want to run it low but don't want to damage anything either. Keep in mind that I have put 5 gallons in it already. Any advice from you is appreciated. Thanks, Gary
   / Ford 1510 Hydraulic Fluid level #2
I'd say run it a couple hours then let it sit an hour, then check again.
Sure you have the right dipstick? Tractordata shows a capacity of 18 quarts. Curious...
Jim
   / Ford 1510 Hydraulic Fluid level #3
Did you measure with the dipstick hanging in the hole, or screwed down?
   / Ford 1510 Hydraulic Fluid level #4
If you have the correct dipstick installed in your tractor, fill the transmission/hydraulics to the indicated level with the tractor shut off and parked on the level.
   / Ford 1510 Hydraulic Fluid level #5
I always check mine with the dipstick down completely. The manual doesn't specify either way.
I screwed it in and it barely registers. I put the whole 5 gal in there.
I have heard that there are 2 dipstick lengths. My tractor is a 1984 year model. Does anyone know what the correct length should be?
   / Ford 1510 Hydraulic Fluid level #8
I've got an "88 1520 so can't help you with a measurement.
Did you check the engine oil level to make sure hyd. fluid is not going into the engine?
   / Ford 1510 Hydraulic Fluid level #9
This may or may not help, but my 1984, model 1710 dipstick measures 7-1/8" from the bottom of the threads to to the end of the dipstick.
   / Ford 1510 Hydraulic Fluid level #10
The parts book is confusing. It list 2 dipsticks: SBA398400310 R/B SBA398400350 dipstick measures 9.13 from underneath cap; years 1-1-1983 to 2-28-1983.
Part no. SBA398400350 R/B 47720351 steel measures 7.68 from underneath cap; years 1-1983 and later.
Gary
2012 Bobcat 90" Finish Mower (A57148)
2012 Bobcat 90"...
Giyi Mini 39" 4-N-1 Bucket (A57149)
Giyi Mini 39"...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2016 Chevrolet Traverse SUV (A56859)
2016 Chevrolet...
2002 CATERPILLAR D6M HIGH TRACK CRAWLER DOZER (A52709)
2002 CATERPILLAR...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
