Ford 1600
   / Ford 1600 #21
It's likely diesel slobber.
Diesels that are not worked hard or are idled alot slobber.
also water can get int he muffler and the soot and water, and unburnt diesel can spray out and leak all over.
real nasty looking.
go run the snot out of it after servicing it. if the slobber stops you are good to go.
soundguy
   / Ford 1600
Changed the oil, found water droplets under the oil fill cap inside the valve cover. Pulled the oil bath filter off, full of watwer instead of oil, real nice. Cleaned all that and ran for a little while, wiill see if it clears up the "spotting". TB
   / Ford 1600 #23
if it is slobber, it will clear up if you get it up to temp and work it till it gets warm.. IE.. don't idle it.. work the bajeebers out of it. if the slobber goes away.. it was a non issue.
do check / change the oil, as it may be fuel contaminated...
soundguy
   / Ford 1600 #24
go for it. (1st post)
New Holland 477 Swather/Mower Conditioner (A52748)
New Holland 477...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
JOHN DEERE SKID STEER 6FT BUSHHOG (A52472)
JOHN DEERE SKID...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
