Ford 1700, any help?
   / Ford 1700, any help? #61
There are plenty of 2wd loader machines out there that beat a shovel and wheel barrow all day long!
-ANY- person that says 2wd is no good as a loader tractor simply has not shoveled and hand carted enough material in his or her lifetime to see the quantum leap of difference between doing it by hand.. and doing it with a machine that may not be awesome.. but in most cases is adequate..
soundguy
Amen to that, I can do the moon walk to a pile of composted cow patties with my two wheel drive tractor and a rear scoop all long and pick up the loot. I get a crick in my neck but sure beats the heck out of a wheel barrow and a shovel... probably it take 30 shovels heaping full before I can fill the wheel barrow once, That's a lot of huff and puff and swetting for me:eek:
JC,
   / Ford 1700, any help? #62
Yep... When i see comments like that.. it always reminds me that some people go right from not doing a task.. to doing it with a 4wd loader tractor with HST.. and not from doing it by hand to doing it with a tractor. Those having never done a task by hand do not realize how much help.. at tool.. any tool is when you are trying to reduce work. Sure.. a 2wd is a mechanized shovel and wheel barrow... sure beats a manual labor shovel and wheel barrow though!
soundguy
   / Ford 1700, any help? #63
I wished I had a loader on mine, I moved 16 yards of sand with a shovel and wheel barrow last winter. Because it was muddy the dump truck couldnt get close to where I needed it, and I had him dump it in the driveway. Then I had to move it out to the pasture and barn to do some fill work. lol I should have waited til summer when the ground was harder. I have at least since then picked up a rear dirt scoop that works well. Smaller loads yea, but it sure beats doing it by hand. I saw some loader kits that fit the 1700 for about 3k or so. They were in Oklahoma somewhere.
   / Ford 1700, any help? #64
Looks like another person with real experience in hand work knows the value of a machine to do the grunt work.
soundguy
   / Ford 1700, any help? #65
JC
I just bought a 1700 yesterday and the dipstick on the tranny is missing as well. Did you ever get a chance to measure the oil level in yours so we can make a substitute up?
Thanks. And thanks for all the other posts. I have covered most of them and have a firm bearing on all that needs to be done to get it back to top shape.
   / Ford 1700, any help? #66
JC
Yes sir Bud,
There you be, look at the pic below and rig up a dipstick out of something. I like galvanized wire that they use to hang ceiling tile. They work great. I'd use a dremmel tool to make the level mark. By the way , welcome to TBN blue.
JC,
PS. The 7 inch is from the top flush. You should not turn the cap tight for measurment.
That's how you read the level.
   / Ford 1700, any help? #67
Thank you. I'll get one rigged up tomorrow and see where we are. The lift bounces like yours did and I can't tell whether it is low on oil or not but best guess is that it is the seal on the lift piston. The tractor sat up for a couple of years inside a barn.
   / Ford 1700, any help? #68
You're welcome. report issues and we'll try to help.
JC,
   / Ford 1700, any help? #69
JC: I sent you a PM if you get a chance.
Thanks.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2010 SHOP MADE WINDMILL TRAILER (A58214)
2010 SHOP MADE...
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
POLY BARREL & WELL TANK (A58374)
POLY BARREL & WELL...
1998 CAT D5M XL (A55272)
1998 CAT D5M XL...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
