would be great to hear back from the op on this.
if it simply is that oring , that would be an ez fix.
as for the biodiesel.. I agree.. I'd think it would soften it and melt it.
when bio blend hit here, I had to run thru lots of the components on my 7610s.. it developed leaks in the fuel system in about 4 places.. orings just turned to black goo..
I went back with buena nitrile rings and havn't had an issue since.
Wow, I figured no one would comment and you guys have been great. The nearest Tractor Supply is 800 miles. I will try NAPA if that's a possibility. No biodiesel in this situation. I have nothing leaking at all.
The Baldwin that doesn't fit is the PF7545 which is supposedly for the Ford 1700 as well.
This may sound foolish, but I'm not sure what O-ring you reference, unless it's for sealling the the cup itself and not filter. I regret not taking a photo looking at the bottom of the fitler holder, but still can if helpful.
I'm measuring directly on the filter holder itself and stating the diameter of the tube that projects down and which the hole in the filter must go over. If there is an O-ring at the upper end of this tube that the filter seals against when the cup is screwed in, it's not part of the problem. If I'm missing the point, please elaborate. None of my filters have come with any O-ring nor did I realize I should be asking for one at the dealer.
I'm crushing the filter itself and simply stating that so you know I'm applying enough force that if it fit, it would go on.
This just doesn't add up and appreciate you guys taking a shot at it. I see my options as:
1. Attempting to mildly modify the hole in each filter element to gain the extra 50/1000. I would only do that if the O-ring you guys reference somehow seals the upper surface, otherwise this risks leaks past the filter.
2. Buying the Ford replacement at $71 given I now have about 8 filters that will supposedly fit.
3. Get one of the Golden Rod replacement filters which looks like a much better setup, but also looks massive to try and mount somewhere.
Please explain the O-ring issue. I really appreciate the comments, Dean
