Cleaned up the frame and battery tray and gave them a quick spray of primer and Ford blue. Bolted it all back together (new bolts, blue loc-tite and torqued to specs). Installed the new solenoid. Started right up !! Let it warm up and changed engine oil and filter and air cleaner oil bath (yuk).
Then on to the trans/axle fluid. Fluid that came out of the trans plug looked pretty good (was wondering if I was wasting my time). Then removed the axle drain plug. First a bit of crystal clear water, then black oil, then gray sludge. Pulled the filter/screen, more sludge (decided it wasn't a waste of time after-all). Thankfully no metal shavings or anything, just tiny bits of Teflon tape. Cleaned the screen and reached in and pulled what sludge I could get to, put it all back together and re-filled with fresh trans/hydro fluid.
Now for the questions. After changing the trans/axle fluid, I fired it back up and was going to cycle the 3-pt. It would go up but not down. And when full up, if I moved the lever into the notch at the top, the loader hydraulic line became very active and started jumping around. (loader is disconnected and hydro line from the tractor loops back to the tractor). Guessing this is the relief valve kicking in and probably needs to be adjusted??
And back to the 3-pt not lowering. Could not for the life of me figure out why it would not go down. Just now went back out and found that the Flow Control Valve was full clock-wise. Backed it out a bit and the 3-pt started dropping. Is this normal (that the full CW position would "hold" the 3-pt regardless of the lever position)?
Next phase, fab a battery hold-down, new battery, some minor electrical. Most everything is unplugged and dangling. Blown fuses. Broken hazard light switch. But the horn works !! Then the hood will go back on and I'll move on to the loader brackets.
-Neil
