Ford 1710 4WD
   / Ford 1710 4WD #21
Re: TC25D HST vs Range
You make a good point about RPMs. Diesel engines are designed to run at their peak RPM. If the engine is rated at 2300 RPM and you are moving a load, run it there and let your gears determine your ground speed. You are going to hurt the engine worse lugging it than letting it do it's job at the RPM it's rated for.
   / Ford 1710 4WD #22
Actually, my point was about the hydraulic pump that is part of the HST, but the point about RPMs and deisels is also a good one.
John
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
