Ford 1910 Hydraulics
   / Ford 1910 Hydraulics #1
jeff77indy
Grantsburg, IN.
2007 4110 Mahindra w/ M112 loader.
The three point lift on my 1910 will not lift a 6ft bushhog after the hydraulic fluid heats up. Also when an implement hooked to the three point is lifted to a neutral position not fully up the arms will bounce up and down.
I have replaced all the o-rings in the control valve, could it be the o-rings on the lift cylider, a bad pressure control valve or the is the pump going?
Has anyone rebuilt a pump for one of these? My service manual says to replace it as it is not serviceable and the parts manual does not list a rebuild kit.
Thanks.
Jeff
   / Ford 1910 Hydraulics #2
The hitch hiccupping is most likely the result of a worn lift piston seal. If the seal is bad enough, there is an outside chance that is the whole problem, fix that first. Have you changed the oil and filter recently? Replacing the pump is the only reasonable option IF it is worn out. But you should do a pressure/flow test on it before arbitrarily replacing it.
Thanks.
I have not replaced the filter or fluid yet, the fluid looks good (not milky) and is at the proper level.
I was planning on doing a pressure check, replacing the lift piston seals and replacing the fluid and filter before I think about the pump.
Jeff
   / Ford 1910 Hydraulics #4
Jeff,
One of the first things along with changing the filter would be to check the pressure. There has been quite a few members on TBN that have discovered their pressure to be quite a bit below where it should be.
Frontier BB3296 HD 8' Box Blade (A57149)
Frontier BB3296 HD...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
HYUNDAI 140LC-9 EXCAVATOR (A52709)
HYUNDAI 140LC-9...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
