Ford 1910 timing marks on flywheel & torque specs for manifolds and injectors
   / Ford 1910 timing marks on flywheel & torque specs for manifolds and injectors #1
lolasonomafarms
Sonoma
Ford 1910
Replaced cylinder head on Shibaura 3-cyl diesel on 1983 Ford 1910 tractor. Preparing to adjust valve timing and need some help deciphering the 2 marks on the flywheel. See attached photo.
Thanks for any guidance on how to interpret those marks: TDC and some angle offset?
AND
Can't find any torque specs for the intake and exhaust manifolds and the fuel injectors. Any experience or info on that?
Appreciate the help of this forum.
Chris
   / Ford 1910 timing marks on flywheel & torque specs for manifolds and injectors #2
Injectors, 43-51 ft/lbs
As for the manifolds, there is just a general table in the service manual.
Hope this helps
   / Ford 1910 timing marks on flywheel & torque specs for manifolds and injectors #3
Top mark in your picture is crankshaft pulley top dead center timing mark. Bottom mark is injection pump timing mark. Fuel should stop flowing from #1 delivery valve holder at beginning of injection when the bottom mark aligns with the timing pointer, according to the pump timing section of my FO-46 service manual.
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
2018 FONTAINE TRAILER CO. 50 STEP DECK LOADER TRAILER (A58214)
2018 FONTAINE...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
