Ford 1910 timing marks on flywheel & torque specs for manifolds and injectors
   / Ford 1910 timing marks on flywheel & torque specs for manifolds and injectors #1
lolasonomafarms
Sonoma
Ford 1910
Replaced cylinder head on Shibaura 3-cyl diesel on 1983 Ford 1910 tractor. Preparing to adjust valve timing and need some help deciphering the 2 marks on the flywheel. See attached photo.
Thanks for any guidance on how to interpret those marks: TDC and some angle offset?
AND
Can't find any torque specs for the intake and exhaust manifolds and the fuel injectors. Any experience or info on that?
Appreciate the help of this forum.
Chris
   / Ford 1910 timing marks on flywheel & torque specs for manifolds and injectors #2
Injectors, 43-51 ft/lbs
As for the manifolds, there is just a general table in the service manual.
Hope this helps
   / Ford 1910 timing marks on flywheel & torque specs for manifolds and injectors #3
Top mark in your picture is crankshaft pulley top dead center timing mark. Bottom mark is injection pump timing mark. Fuel should stop flowing from #1 delivery valve holder at beginning of injection when the bottom mark aligns with the timing pointer, according to the pump timing section of my FO-46 service manual.
MASSAGE CHAIR (A58214)
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2004 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A58018)
2004 FREIGHTLINER...
