Ford 1910 vs 1920
   / Ford 1910 vs 1920 #1
tmc
I am a first time tractor buyer looking for a used 4 wheel drive tractor with loader to maintain 35 acres. I've found a Ford 1920 without a FEL for $10000, and a 1910 with FEL for $7500. Both have just under 500 hours. Is the 1920 worth the extra $. I assume I could add a FEL later. Any recommendations?
   / Ford 1910 vs 1920 #2
According to the information on another website, 1910 was made from 83-86 and was 29 hp at the pto. The 1920 was built from 87-2000 and was 29 hp at the pto. If you are going to need the loader I would go for the 1910 as a loader is going to run at least $3,000. This is of course if they are both four wheel drive. Other opinions may vary. /forums/images/graemlins/grin.gif
   / Ford 1910 vs 1920 #3
I had a 1710 for many years and a 2120 from 1987 until now, so I have experience with both series. They are both good tractors. Very dependable. The hours are very little. What trannies do they have? The 12x12 shuttle in the 2120 is a big improvement over what ever I had in the 1710. 20 series parts are also very available. I'm not sure about all 10 series parts. A local mechanic had problems getting some internal trans parts for a 1910. I would ask RickB or Spencer200 about parts availability. The 1920 is a somewhat more capable tractor. I think the loader would be in the 3-4,000 range. How are the tires. Are they loaded? I just had to do some welding on a rusted out valve stem area on the 2120 due to calcium use. The 1910 is older. I would not be afaraid to purchase either tractor depending on the trans in it.
Andy
   / Ford 1910 vs 1920 #4
Ditto what the others said. The 1920 is a great tractor.. I owned one for a few years.
Tranny options will make a difference.. and parts availability would be my determining factor.
Soundguy
   / Ford 1910 vs 1920
Thanks for the input. I could list all the reasons I'm going for the 1920, but the truth is my wife liked it better. Maybe I should let her drive a new one.
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
Kubota RTV-X1100C (A51573)
Kubota RTV-X1100C...
