Ford 2000 3cyl gas--Hydraulics
   / Ford 2000 3cyl gas--Hydraulics #1
ron65729
Ozarks--where rocks grow better than weeds
Ford 2000
Hello everyone--Newbe here--I have a Ford 2000 with front loader. I have installed a front crank driven pump on it, but am unhappy with it. I am wanting to go with the hydraulic adapter plate that mounts on top of the transmission.
Any pros or cons about this, and does this adapter work as good as a pump.
   / Ford 2000 3cyl gas--Hydraulics #2
Welcome to TBN. :)
   / Ford 2000 3cyl gas--Hydraulics #4
Front pump provides speedier loader though sometimes less power full.
The under the seat / tractor hydraulics and slower and sometimes more powerful.
DS
   / Ford 2000 3cyl gas--Hydraulics #5
DS
   / Ford 2000 3cyl gas--Hydraulics #6
why would you be unhappy with the front pump? it is almost assuredly more gpm than the built in pump. even if a small ring 8gpm setup it should outprerform the engine pump.
normal ag op psi is 2500 psi.. perhaps the laoder control valve is set real low on relief.. or the pump is bypassing.
need WAY more details.
given that the tractor hyd system won't be over 2500 psi.. I'd not say it will operate at a higher pressure than an external pump.
relief value ont he loader valve may be the limiting factor unless the front pump is worn out..
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
1997 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1997 HEIL TRAILER...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
