Ford 2000 3cyl gas-wont stay running
   / Ford 2000 3cyl gas-wont stay running
</font><font color="blueclass=small">( Re-read Rick's post, check those 3 filters. Also, I'm not sure how that tank is vented, through the tank or at the cap, but check that too. )</font>
Howdie, I have taken the gas tank completely off of tractor and cleaned it out, put several small ball bearings, washers and small nuts inside of it and had a **** good time dancing to the Labamba with it as my partner, several times over. Oh yea I did put some tank cleaner in with all of the nuts. Cleaned out the screen in the cut off valve in the tank, was pretty nasty, but sparcklin clear now. I will check the other two this mornin when the sun gets up. I will probably go ahead and take the carb off and check the inside of it while I am at it. Does anyone know what the float should be set at, or how I should set the the idle screw, or whatever ya call it, only has one. Thanks for all ya'lls HELP. Bullfrog
Oh and as the tank vent, I do not know how it is vented. One thing I have noticed is, I did cut the fuel line between the tank cut off valve and the fuel pump and installed an in-line gas filter. Now after it has started and ran and shut off deal, I can take the glass bowl off of the original strainer and it seems to have some back pressure or some kinda pressure now that it didnt before I put the new inline filter on it. Is this my imagination or could this really be happenin? Thanks again <font color="black"> </font>
Sorry dont know how the **** color changed, but maybe this fixed that at least.
   / Ford 2000 3cyl gas-wont stay running #12
On the old gravity feed systems, like on the N and hundred series tractors, an inline pleated fuel filter sometimes effected fuel flow... with apump i doubt it.
Sounds like your bowl is going dry.. might be crud in the needle. Grab a carb kit and some cleaner and go for it.
Soundguy
   / Ford 2000 3cyl gas-wont stay running #13
sounds like a fuel problem. Take the new in line filter out and splice in a peice of hose and see if that corrects the problem, also some filters can be put in backwards and not work right. just a few more things to try.
   / Ford 2000 3cyl gas-wont stay running #14
Another point, some inline filters are for gravity feed and some are for fuel pump systems. I put one for a pump type system on a gravity feed briggs once and it would not rev up all the way, changed to a gravity feed type and all was good.
Ben
Pallet of 22 Misc Wheels (A51573)
Pallet of 22 Misc...
1268 (A50490)
1268 (A50490)
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
