Ford 2110 balky power steering
   / Ford 2110 balky power steering #1
dr2ths
syracuse ny
Ford 2110
My 2110 will at times be difficult to steer other times normal except for excessive freeplay
   / Ford 2110 balky power steering #2
Does your unit have two sector output shafts? Pictures would help.
There should be an adjustment screw to set the backlash on the gears. If it has two shafts there is two adjustment screws. To adjust, loosen the jam nut at the base of screw. Turn screw clockwise to tighten the gear mesh. I like just a little movement of steering wheel with no movement of pitman arm.
After backlash is properly set, hold screw with screwdriver and tighten the jam nut. That should reduce the slack in steering and could help with the hard steering issues.
Good luck and let us know what you find.
Thank you. I値l have a look and try that.
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2013 Freightliner 122SD Day Cab Truck, VIN # 1FUJGNDR3DDBZ7701 (A54865)
2013 Freightliner...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55218)
2016 RAM 5500...
John Deere utv cart (A55787)
John Deere utv...
