Ford 3.5 Econoboost
   / Ford 3.5 Econoboost #11
I think the eco is like a diesel. You have so much power and torque on tap its hard not to hit the fun pedal. This leads to low mpg. If I drive my diesel like a little old lady I average 17 but stay on the fun pedal and its 14.
Chris
The lower speed limits up here would help get better mileage too.
Thanks for all the replies. I hold on to cars/trucks for a long time. My GMC is a 2003 with 135,000 miles and runs very nice. I did not buy it new and while it runs impressively well, it has not been a cheap truck to maintain. My wife and I call it a very high maintenance truck. I am not familiar with turbos and sure don't want to get into something that ends up being high maintenance. I'll have to do some more reading about turbos to learn more about them.
   / Ford 3.5 Econoboost #13
A turbo would not scare me. All diesels are turbo. Now a turbo from the 80s, yes, but today, no.
What has made your GM such a high cost to maintain and run truck?
Chris
   / Ford 3.5 Econoboost #14
Turbos built today are not a problem if you can resist the temptation to open'r up on a regular basis. That said, you need good oil in it.
   / Ford 3.5 Econoboost #15
Reliability of turbos is not a problem. I have had many turbo vehicles over the last few years, and all have been very reliable. To me the problem is that the performance/efficiency tradeoff is very bi-polar -- you can have power or you can have fuel economy, but you will never get both and there is no happy medium like a normally-aspirated engine. If you drive like a granny most of the time, you should get excellent mileage out of an Eco-boost. If you need the power or drive at high highway speeds (where the engine will boost all the time) then expect lousy mpg. It's the way turbos have always been, and the Eco-boost is no different. I'd wager that the Eco-boost might be a little worse at high speeds than normal turbo cars just because pickup trucks are like a brick with a parachute attached in terms of aerodynamic drag.
For what it's worth, I shopped F-150s pretty heavily last December, and I very quickly gravitated towards the 5.0 V8. I just liked the overall feel of the engine throughout the performance envelope more than the other engine choices. It's a very relaxed easygoing engine.
   / Ford 3.5 Econoboost #16
I recently bought a 2012 Toyota Tacoma double cab 4x4 with the v6. I downgraded after owning two z71's, one which had the 6.2 v8 in it. Awesome engine btw, just wish they'd come out with it four years ago when gas was affordable. Anyways I get asked a lot by friends why didn't I go buy an ecoboost. Honestly I probably should have at least gave one a hard look but I was deadset on a Tacoma. I personally don't know anyone that had that engine as most of my ford friends drive diesels, 5.4's and 5.0's. Does the ecoboost run on 87 octane? I would think the ideal gears for optimal towing performance ad fuel economy would be the 3:73's correct?
   / Ford 3.5 Econoboost #18
Yes, the Ecoboost uses 87 octane. As for the gears they offer a 3.15, 3.31, 3.55, & 3.73. The 3.73 like my father has makes it a stump puller but most I see on dealers lots have 3.31 & 3.55 gears. Personally I always get the lowest gear. I buy trucks to work. Whatever mpg it gets it gets. I have a car for 30 mpg if needed.
The six speed in the eco with the 3.73 gears really let it shine. I drove one with 3.31 gears and there was a major difference.
Chris
   / Ford 3.5 Econoboost #19
Same here. My Avalanche cost around $1500 per year in maintenance. Granted, I took it to the shop for everything, but that's still salty. Two failed window motor assemblies, brakes, rotors, pads, discs, rotors - did I mention the brakes? :) Daytime running lamps were always, always burned out. My father had a similar experience with his Suburban...brakes, idler arms, other steering components...GM just doesn't design those components well. However, the 5.3 and the tranny in it? Couldn't kill it. Had 140,000 miles on it when I traded it in, and ran like it was new. My father is still running his 'Burb.
The 3.5 Eco feels like a diesel as someone else stated. Not as smooth when not towing a load though... Sort of "skips" a bit. Under a little throttle, or any load, and she's smooth. I rarely run premium in mine though...maybe that's the reason.
   / Ford 3.5 Econoboost #20
Chris
Thanks for the info! So many dagblasted engines these days run on 93 seems like. That's one big thing I did not like about the 6.2 but knew going in. Just was not expecting gas to climb like it has and stay there. I would prefer the 3:73's myself I think. That's what my Tacoma has. My biggest problem with GM trucks is their minimal gear offerings. Hate the new trucks that come with 3:08 and 3:42. What crap. I'll be keeping my Tacoma for a long while but might pickup a bigger truck somewhere along the way to have around the farm.
9 OFFICE CHAIRS (A53843)
9 OFFICE CHAIRS...
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
2011 Kubota L3200 (A50123)
2011 Kubota L3200...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
