Ford 3000 Banging the Bendix on the Ring Gear
   / Ford 3000 Banging the Bendix on the Ring Gear #1
Ford 3000 Gas
Hey Folks, first post here! I have a 1970 Ford 3000 Gas. I recently split the tractor and flipped the ring gear due to damage from the bendix beating on the teeth several times when starting, due to it not engaging. Once it does engage, it cranks fine.
Now that it's flipped, I thought it would have stopped doing that. Can the starter angle be adjusted/shimmed to engage properly? At present, that seems like it might be a solution. Thanks in advance!
   / Ford 3000 Banging the Bendix on the Ring Gear #2
Sounds like you are really savvy with your older machine. I’m just wondering if the starter and all are good now that you have eliminated the ring gear.
Fixed! I took the Bendix from the original dead starter and put it in the rebuilt starter and problem solved. The gears on the ford unit were beveled much more cleanly and every turn of the key engaged the flywheel perfectly.
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
New/Unused 2025 H12R Mini Excavator (A51573)
New/Unused 2025...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
