Ford 3000 Hydraulic Filter
   / Ford 3000 Hydraulic Filter #11
Hi there
I'm yet another 73 Ford 3000 owner with the same symptoms - no position control with the selector lever in the vertical position.
I was curious whether you found the cause on your tractor and how difficult it was to fix.
Cheers
Calvin
   / Ford 3000 Hydraulic Filter #12
No control at all.. or it won't go up at all.
typical position control problems involve the cam, and cam pin.
soundguy
   / Ford 3000 Hydraulic Filter #13
Hi had the same problem, stucked in draft control. I found out that a little plate at the end of the position control rod was at an angle (So it was sitting over the little pin, the ones who saw it may understand what I mean, if not I'm sorry :eek: .) Just turning it at the right angle fixed the problem. I have to say that the selector lever was almost moving freely, now I can feel the resistance of the spring.
So it's working good now, what an improvement. We use the tractor mostly with a logging winch and a bush-hog, sometimes with a blade or a scoop.
It seems strong but not at the point to lift the front wheels off the ground. Skidding a full length 20-inches maple, I hear a hissing sound in the back and it gets slow to lift, but the relief valve doesn't seem to become that warm. May-I had broke a O Ring on the pressure pipe when I put the cover back on?
   / Ford 3000 Hydraulic Filter #14
sounds like the relief venting to me...
soundguy
   / Ford 3000 Hydraulic Filter #15
Did you have any problems getting the lift cover off? I am trying to pull mine on a 71' 3000 to replace the filters and it wont budge loose. I've got all the bolts out???
Did you have to work hard to get it off or am I missing something?
   / Ford 3000 Hydraulic Filter #16
use a piece of 2x4 and a bottle jack.. prop her up under a lift arm on the top cover and jack up a bit.. let gravity work for you.
soundguy
   / Ford 3000 Hydraulic Filter #17
I know this is a really old thread but maybe soundguy can let me know. I have a '71 ford 2000 gas 6 speed. to get the hyd. suction filter out, do I need to split the tractor ?? The I&T manual does nothing to explain how to remove filters from tractor.
   / Ford 3000 Hydraulic Filter #18
Well I got it out without splitting the tractor. Just bent the mounting tab out a bit, wiggle, wiggle, wiggle, swear, swear, drink, drink, ahhhh it came out. Also needed to pull out the PTO shaft and remove the shift collar and fork.
   / Ford 3000 Hydraulic Filter #19
not a fun job...
   / Ford 3000 Hydraulic Filter #20
I guess I am a day late and dollar short answering this...
As you have already figured out, you don't need to split the tractor. For me, the worst part was pulling the lift cover - by myself... Glad you got it done.
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
