Ford 3000 hydraulic fluid in crankcase
   / Ford 3000 hydraulic fluid in crankcase #1
l huseman
Ford 3000
I have a Ford 3000 and hydraulic fluid in going into motor crankcase pretty quick. Is it hydraulic pump seals or worn out pump?? Any ideas appreciated!
   / Ford 3000 hydraulic fluid in crankcase #2
Does your 3000 have a hydraulic pump on the right rear side of the engine?
My 3910 and 4000 Ford tractor and both of the hydraulic pumps are in the rear differential. If I were to get hydraulic fluid in my engine, it would have to come from the power steering pump, and they can put hydraulic oil in the engine.
Sitting in the seat, it’s on the left front side of engine
Ohh so it might be the power steering pump?? Interesting. I am a shade tree mechanic on cars. The tractors are new
   / Ford 3000 hydraulic fluid in crankcase #5
If it were the steering pump causing the problem, you would be out of steering fluid every day. The can only holds a quart and a half. How much over full is the engine oil level, and is the hydraulic reservoir low? Your piston pump is the more likely culprit in my opinion.
Forgive my lack of knowledge on this. The piston pump? Where is that located— I am thinking on the left side of motor. The power steering pump?
   / Ford 3000 hydraulic fluid in crankcase #7
2016 FORD TRANSIT 350 CARGO VAN (A59905)
2016 FORD TRANSIT...
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2014 NISSAN NV CARGO VAN (A59905)
2014 NISSAN NV...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
