Lenny: If this is the case, what would be the remedy? Check the valve clearances, broken springs? Or something else? Thanks.
Another long winded explanation post. You all have been warned.
First is getting the timing set.
If the timing or wiring is off, the plug fires at the wrong time while a valve either intake or exhaust is open. We’ve discussed that ad nauseum.
If a plug wire(s) are not correct, then the rotor will line up and fire the wrong plug at the wrong “time” (hence the word “timing”).
Example
Say you wired it backwards to the rotor rotation.
Firing order is 1-2-3. But since the rotor is turning the opposite way, the rotor is going to line up in order of 1-3-2.
Plug fires at number 1. Both valves are closed. Piston is near top on compression stroke. All is well.
Rotor moves to next plug. Supposed to be #2. But it is connected to #3.
Well, 3 isn’t ready yet and is still on its intake stroke going DOWN. The Intake valve is OPEN drawing fuel/air mixture from carburetor.
Spark explodes and the fire/explosion travels back through intake valve which is open out to carb.
Rotor travels on to what is supposed to be #3. But it’s connected to 2.
2 cylinder missed its spark (went to 3 remember?)
So it has went over the top of the compression stroke went down on its POWER stroke and is coming back up on the EXHAUST stroke.
Exhaust valve is open to let spent gassed out.
(Extra useless info alert. The camshaft is turning only 1 time to the crankshaft’s two times. That’s why there are two strokes there of the crankshaft. The distributor is turning in relation to the cam shaft 1:1 while the camshaft is in a 1:2 ratio with the crankshaft).
Meanwhile, back at the ranch.
And here comes the rotor and fires what it thinks is #3 but it’s actually connect to #2.
Plug fires on the exhaust stroke, piston can’t go down (the crankshaft is forcing it up, the exhaust valve is open and so the fuel air mixture that never got burnt before explodes and pushes out the EXHAUST valve to the pipe for a “backfire” out the exhaust.
Sequence of events.
Rotor moves to # 1 plug wire at same time as #1 piston is at TDC of Compression stroke.
All is well and the stars are all in place in the universe so piston is driven back down correctly keeping the engine “running” under its own power.
Then when that 2nd plug (which is actually #3 Cylinder fires at the wrong spot, that piston is on its down on the intake. Intake Valve is Open. Engine gets a little more “nudge” to keep running with Piston already going down and the explosion above it.
3rd plug fires. Which is connected to #2 CYLINDER. it’s past it’s compression and Power Stroke and on to the EXHAUST stroke. It missed it’s chance since #3 cylinder got the spark supposed to come to it at the right “time”.
Inertia carries through the stroke and till 1 bangs again to repeat the cycle.
Clear as mud?
This would be a better explanation if you were here next to the wood stove here in my shop over cold beers like I am (well coffee... it’s still a little early for Sunday beers even for me! Better give it a couple more hours at least.)
When that is verified as correct, then you go into all the tests/ checks others have mentioned. They are right.
