Ford 3000
   / Ford 3000
That tag is no longer there.
   / Ford 3000 #12
how u can tell if it is really a 3000 is if it has drie drum brakes the hyd pump does not have the filter on it, is 3 cyl. and has the flow control valve on the side of the rear diff. on the right side
   / Ford 3000
3000 is wrote on the hood. But yes it does have the flow control valve it is a 3 cyl. The hydraulic filter is in the rear end done changed that already.
   / Ford 3000 #14
what is the 3 for
if his date code makes it a 66 model.. which it looks like it does, then his model id will start with a 3.. if it is a 4-68+ model it will start with a C
soundguy
   / Ford 3000
Guys I never could find nothing on that only others I have found.
6L4C
L166
B831166
Engine has others production #
E
60L13
4F20C
Engine serial #
*C641228*
On transmission production code under hydraulic pump
C7008
That's about all I found
Thanks,
   / Ford 3000 #17
It looks like the engine has been replaced, it´s from 1974.
   / Ford 3000
That's what I was thinking but he said no but also his 94 years old but the engine starts with a c is that united states make if so the trans. Also starts with a c. Couldn't find a # on the rear axle.
   / Ford 3000 #19
i believe you are confusing model and serial number.
sn on the trans bellhousing will begin with an A for antwerp belgium, B for basildon england, or C for a US made one.
the Model ID number for a 3000 series will begin with a 3 if it is before a 4-1968 model, and C if it is a 4-68 or later model.
soundguy
   / Ford 3000
This is a couple of pictures
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2012 Chevrolet Cruze (A50324)
2012 Chevrolet...
2021 Acura RDX SUV (A50324)
2021 Acura RDX SUV...
2019 KOMATSU PC290LC-11 EXCAVATOR (A51242)
2019 KOMATSU...
