Texasmark
Elite Member
- Joined
- Apr 24, 2012
- Messages
- 3,703
- Location
- N. Texas
- Tractor
- Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
2100 about.
Yes cables are all good.
There isn't any smoke. It starts right up the first time and runs fine. IN the winter when it is cold it takes a bit or a spray of ether to get it started but someone unplugged the manifold heating unit from the ignition because the key is wonky and i am not sure they knew that it had a heating element and it was draining the battery.
Again there is no smoke other than the normal little bit on start up when it has been sitting for a long time. The oil was black but it is unknown when the PO changed the oil last. I runs fine. It just struggles under load and there is some smoke out the crankcast vent and oil misting. No sludge when i changed the oil in the bottom of the pan that i could feel as i checked for that just to be curious on my oil change.
Ok, you are tracking me so I'll move on from what I just posted. I don't see an overhaul just yet....don't go to all that trouble and expense unnecessarily! Sounds more like under load you are asking your injectors for more "fuel mist" and they can't deliver as required.
First off change the oil and filter. Run a single wash out cycle as mentioned above. Then with what you said above refill with a new filter and a C rated 15w-40 oil is what I'd use and I use WW oil in my Fords, been doing it as long as I can remember, or go with Shella Rotella T, or Delvac, or the other popular oil co. C (compression) rated tractor oil...D something. While at WW get some SF anyway and put a whole can in your diesel fuel tank and top it off. Run that fuel out working as you are now and come back with the results. I use a fuel cleaner in my fuel always and have no fuel problems. On that, I use Power Services products which are popular.
I think you may be suffering from lack of working your tractor, both by the PO and yourself, meaning getting it under load with clean fuel/lubes/internal components, getting the temperature up and all the working parts hot (not overheated, hot at rated temps) and blowing the crud out. Do what I suggested and give it time to clean up internally. Report back.
One last thought in reading over this is that your fuel filter(s) may need changing with 2000 hrs on the engine if they haven't been changed over the life of the tractor, way past time. Get yourself an I&T service manual for your tractor.....
I&T Shop Manual FO-41 Ford 231 26 261 36 361 411 46 461 461SU+ | eBay
Will tell you how to change your fuel filter and bleed the air out of the system and while on ebay, might as well buy replacement(s)....just plug "Ford 3600 diesel fuel filter" into the ebay search engine.....here I did it for you:
EDPN9N 74AA NEW Fuel Filter For Ford 2 3 4 5 7 26 36 46 + | eBay
