Price Check Ford 4630 or 3930
   / Ford 4630 or 3930
If I get this 4630 one of the first things I'll need is a hay spear. Can anyone give me a recommendation on a quick attach setup. Is that the route I should take?
This started a new page, make sure to look at the pics I posted prior.
   / Ford 4630 or 3930 #32
This is the lower left rear mount for the loader and the right. Very slight deformation of the metal where the loader met the pin (slight mushrooming). Didn't look bad to me.
The next pics are on the forward bracket of the loader. There's a bolt missing on both sides, and these two plates would shift under load about 5 degrees, from being misaligned up to misaligned down.
Replace the missing hardware, torque all existing hardware, done.
   / Ford 4630 or 3930 #34
These hoses seem overly long. Is there a better solution?
They need to be that long so you can use the hydraulics to remove & install the loader. There can be better placement and securing of the 'excess', but if you want to retain the ability to easily remove the loader, there's not much else that can be done.
   / Ford 4630 or 3930
I just saw an Ebay post for a Ford 4430 4WD w/cab. Haven't seen many 4430s, nothing on them on Tractordata.com. Was this not a very common tractor, or for a special purpose?
   / Ford 4630 or 3930 #37
The Ford 4430 is a narrow orchard tractor. 100% pure Fiat design and built with absolutely nothing in common with a 4630 other than the shade of blue.
   / Ford 4630 or 3930 #38
Out of curiosity, what is this rod for that enters the rear axle case on the front left side? That's the foot board just forward of it.
did you follow that rod to see where it went? :)
soundguy
   / Ford 4630 or 3930 #39
I have nose hairs that bother me more than that.
I am going to have to stop drinking while I read these posts.. I narrowly avoided spewing iced tea thru the nose when i hit this one! :)
soundguy
   / Ford 4630 or 3930 #40
I am betting this tractor will not set on the dealers lot very long. Ken Sweet
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
TRUCKING INFO (A50775)
Electric Concrete Mixer (A51573)
Electric Concrete...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Entyre Chip Spreader (A51573)
Entyre Chip...
