Ford 5000 restore
   / Ford 5000 restore
I wanna see some pics once this baby is done. If you want input on paint I can give you some information to mull over. My 3910 should be done next month. Nothing like a old Ford tractor.
Did you ever get your 3910 painted
   / Ford 5000 restore #42
Were doing the decals so yes all metal is done now. I will try to get some new pics for you this week.
   / Ford 5000 restore #43
By the way i was reading your post regarding the balancer. Does my 4000su have this? Im asking as the engine runs rough during certain rpms and smooth during other rpms. Having a hard time figuring out what the problem is.
   / Ford 5000 restore
Clutch time
Rear main seal install
Rear of camshaft
Camshaft rear cover with o ring a couple dabs of silicone is a plus
Rear motor cover I forgot to get a pic there is a cork gasket that goes between it and the back of the motor it covers around rear main seal torque bolts to 25-30 ft lbs
Fly wheel installed there is an adapter that goes on before bolted on
Torque to 160ft lbs I just shot it with the air gun
Clutch alignment tool used for 3000 4000 and 5000
Clutch disk being held by clutch alignment tool to flywheel
Clutch
The pin goes in this hole two are on the flywheel and they hold the clutch In
Finish product
Motor installed little truck to help line the motor up lift with engine hoist put four bolt in corner slots spin crank shaft and push while spinning
   / Ford 5000 restore
Time for some timing very easy. most important thing is make sure your not 180 degrees out on your cam. very simple number 1 and 4 piston is top dead center put two push rods in no.4 and turn your cam left then right both rods intake and exhaust should rise in either direction this lets you know you are on a compression stroke.
Also remove your cam gear to put your front motor plate on the your injection pump is hooked to all four bolts that hold it on should torque 13-18 ft lbs I did mine to 20
Lets start with the injection pump time these two notches will line up on injection pump shaft and housing
Leave injection pump gear bolts lose so shaft doesn't spin when aligning gears
At this point you can right inj pump gear bolts injection pump to idler gear or camshaft drive gear same thing note how the dots line up they don't really just count the tooth and groove
Idler gear to camshaft gear dots line up
Idler to crank gear dots
Connecting rods are level you can take a straight edge and see how they line up if 180 out exhaust valve will be open on no.1
All the gears lined up
Idler gear bolt torque 100-105 ft lbs
   / Ford 5000 restore #46
great thread thanks for all the pics and details. I have a 5000 that I just did a compression test on and it only has about 220psi on each cylinder so it looks like I am going to need to do a rebuild. what did you use for a rebuild kit? I have found tisco brand kits for around 500ish on tractorpartsexpress that include pistons rings bearings and all gaskets. are these good quality parts? are there better ones to go with?
   / Ford 5000 restore
I'm not really sure to tell you the truth man but I bought all mine from agkits.com all the parts iv bought from them were in spec but tisco I think are good parts too may want to check Madisontractor.com always have been right on with bushings and bearings when iv ordered
   / Ford 5000 restore #48
TISCO is a good company, They have been in business a long time and have been supporting these older tractors since they were new.
   / Ford 5000 restore #49
and supporting some of them with some pretty cruddy equipment too!
tisco points are about the worst you can get on the planet!
   / Ford 5000 restore
I know it has been a long time since this post and I just saw it the 4000su is a 3 cylinder so no it does not have a balancer only 4 cylinders
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
