Today I drained the hydraulic tank and removed the inlet hose. There was no screen or snap ring. Someone removed it and never installed it. Since I was thar far I removed the entire inlet hose to the pump to make sure nothing was stuck inside it. Nothing was. After putting everything back together I went to the backhoe value block. The boom hoses look to have been replaced not that long ago. The boom valve had the small round can looking cap on the top of it. I removed it. I'm almost sure it is an adjustable pressure relief valve. I took it apart, cleaned and reassembled it the same way it was. It was clean on the inside. After reinstalling it the hoe still works the same way. There is something else on the lower side of the boom valve. I'm not sure what it is. After it was together I had some more time to work all the functions. I now realize that when working the dipper nothing else works at the same time. No swing left to right, no bucket curl, and no stabilizers. When working the boom everything else will work with it but everything seems slow to move.
