Ford 6610 4wd...too much tractor?
   / Ford 6610 4wd...too much tractor? #11
Hard to tell anything from the pics, looks like more than the arms are missing off the 3 point hitch. PTO hasn't been used much apparently. Not sure what that rear attachment is. I'm not good at Ford models. Did plow a couple of acres with an 8630 on the weekend though!
Another pic of the cab:
And a pretty useless one of the tag showing what it is:
If I were going to do what you say you wanted to on hilly, treed land, I would do all the clearing work with a crawler type machine and not a wheel tractor. Buy or rent a small cat to do this. It's so much safer on steep ground and they are shielded so you won't put stick through the radiator or rip off a hose , etc.
Once you have the place cleared and all the rocks and logs pushed and dragged to where ever, sell it and get a wheel tractor with a wide stance to maintain the place, build fence, mow etc.
I had a wooded place and working with a wheeled tractor was a pain.
Money is our main negative...we have a lack of it.:D
Have thought of just getting someone in to do the clearing all at once with heavy equipment but have heard that can have a negative impact on the land and the remaining trees.
I have used..okay abused the poor little Massey doing the little that has been cleared,using the loader bucket as a battering ram to take down whatever it can then cutting it with the rotary cutter....not pretty but has worked.
   / Ford 6610 4wd...too much tractor? #14
The thing about bigger/higher HP tractors is that you really should have the implements to match and they just plain cost more. I would never run my RFM on that big of tractor for example, but it is great on my Kubota L3130.
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A52577)
2016 INTERNATIONAL...
SNOW DOG SALT BOX TRUCK MOUNT SPREADER (A52577)
SNOW DOG SALT BOX...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
