ford 845 diesel?
   / ford 845 diesel?
what I've got is 641D ford.. Now i need to find new generator or convert to alternator. old one doesn't gen.
   / ford 845 diesel? #13
could just be a voltage regulator???? Those are cheap.
Now for the tractor, are you happy with the price you paid for it. Because I'd be pretty upset if I though I bought a 62HP (engine) tractor and found out it was a 48hp tractor.
   / ford 845 diesel? #14
   / ford 845 diesel? #15
motor test the genny.. if it motor tests good.. might just need a new reg.. or even wireing.
that should be a 12v gen from the factory. you can get new ones from india for about 90$.. regs are 25-40$
Or you can convert to an alt with a tisco bracket set and a 55$ delco 10si 3 wire ( prefered ) alternator.. go with an idiot lamp setup if you go to an alt. don't get the 1-wire jobs... imho..
   / ford 845 diesel? #16
Oh yeah... i started typing and forgot this was a diesel. In that case it would be a good idea to check the gen.
   / ford 845 diesel? #17
Double post...sorry
   / ford 845 diesel? #18
And show us a pic. Welcome to the forum
   / ford 845 diesel?
think i want to change to alternator instead of keeping generator. need source for one that works on diesel. should it be one or three wire?
   / ford 845 diesel? #20
IF the tach is driven off the generator, you will either loose the tach, or it will be more $$$ to go to an alternator w/tach drive vs just replacing the genny.
Soundguy knows what alternator is compatible, I am sure he would be along shortly. Personally, I'd find out for sure if it is the genny or the v-regulator. And even if both are bad, you likely cannot convert to an alternator w/tach drive for less money than just replacing BOTH the generator and v-reg. But odds are, they both arent bad
4 Drums of Paraflex (A51573)
4 Drums of...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
