Yea I going to push this 800 into the barn. I don't see a quick fix. There been tractors popping up in the adds for sale . Like this one for $1000. I wish I had moved on that 871 with the bad SOS. It had a good engine and for $1500 it include a brush hog. The tractor had a hydraulic plow on the front. For $1500 it sat for 3 weeks. I saw in PA a Jubilee with another bad SOS in it. I thought they did not come out till like 59. I assume someone put it in that tractor. It was running with good rubber and pie weights. $500. It was gone when I called. A 640 with loader will not run for $900. it was gone. Yesterday another 600 bad clutch $800. If it had an 172 I would of called sooner. Then I thought of my brothers 620. But it was too late. My first piece of equipment I bought was a 9N. over 25years ago. I was dumb and the guy who owned was not very knowledgeable. It was running and when I warmed up the oil pressure went from 20 to little or nothing. He said that gauge can't be right. I agreed. I bought it. I used it to haul firewood and to run a brush hog to cut maybe 5 acres. After a few years I put a new oil gauge and line. That old gauge was correct. I had been using this for about 4 years. I took a compression test I think it was like 90,85,80,40. The back cylinder was dead and had been since I owned it. I used it for 25 years like that . Fired it up again last week. Those things are bullet proof. With just 3 cylinders it still has power. I have abused it when I stopped using it for firewood. It sat outside for over 2 years . When I decided to use it to brush hog I put a 6 volt bat in it. change the gas. I always turn off the gas and run it dry if it going to sit for the winter. It fired right off. The clutch was stuck I had to drive it down the road for about a mile before it broke free. I never put much into it. Just change the oil, 40 weight with thickener. filers and kept carbs clean. I figured an 800 with 172 running on all 4 cylinders would be great.
