Ford 9N lift arms
   / Ford 9N lift arms
I see 4 bolts which appear to attach the flat belt pulley assembly to the rear case. If I re move these 4 bolts does the flat belt pulley assembly just slide out off the PTO splined shaft?
   / Ford 9N lift arms #12
Do you have a pic, there are different ways that the pulley could be attached.
4 bolts make it seem like it is a 2 piece, 1 piece is the pulley, and the other piece is the hub that goes on the shaft.
If 2 piece they fit together with a taper that lets the hub clamp on the shaft when you tighten the bolts.
There should be holes to thread the bolts back in to press the hub and pulley apart.
My best guess. ??
   / Ford 9N lift arms #13
The only one I ever saw was like that. Remove 4 bolts, entire assembly slides off the splined PTO shaft.
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
